Airfix 1:72 HS Buccaneer S2B
  • colin m
    • 9066
    • Colin
    • Stafford, UK
    #31
    Well, finally finished. There was a slight delay in finishing it off !! The result has been posted in the 'Aircraft pictures' section
    Colin M...
    • HAWKERHUNTER
      • Feb 2012
      • 2074
      • Steve
      • Halifax, West Yorks.
      #32
      Hi Colin. You really wetted my appetite with this build so I picked one of these up last week.The PE is on its way. I notice the model has a lot of raised panel lines which Ive never worked with before so it should be an interesting build. Ill probably use a different cameo but havent decided yet.
      • colin m
        • 9066
        • Colin
        • Stafford, UK
        #33
        Hello Steve,
        I'm afraid there isn't much to choose from if you want a 1:72 Bucc'. The Airfix option needs a bit of work but it turns out alright. I re-scribed mine all over. Not something I've ever done before apart from restoring the odd line lost during sanding.
