Tamiya Hyakushiki III 1/48
    Office looks great Michael. As for the pe mostly I use medium foam safe ca,but I also use 30 minute epoxy if I need more work time. cheers Trey
    • michaelm
      • Dec 2011
      • 437
      #32
      Ok, got the airframe together, fit was real good it will just need a small scrape of filler here and there.
      Next was everyone's favourite job......canopy masking, not something I relish but I think I'm getting a bit better, and faster, at it.
      Tried the Canopy pieces on dry and they look like a nice fit, looking forward to getting some paint on soon. M
      [ATTACH]59175.IPB[/ATTACH]
      [ATTACH]59176.IPB[/ATTACH]
      [ATTACH]59177.IPB[/ATTACH]
      [ATTACH]59178.IPB[/ATTACH]
        Canopy mask looks clean and tight Michael,also looking forward to seeing some paint go on this. Have you decided on a scheme yet?
        • michaelm
          • Dec 2011
          • 437
          #34
          Things are moving on a bit with this build now. Canopy on, it was a little tricky as there are quite a few clear parts to stick together but its on.
          Gave it it a coat of the cockpit interior colour so the inside frame of the canopy matches the inside of the cockpit.
          Did some pre-shading on the underside of the aircraft, I've tried this before but usually obliterate this with any further coats of paints, so far I think its ok but I think I'll need another light coat of the grey so we'll see how it is after that.
          I've also sprayed some Alclad Airframe Aluminium in patches where I plan to try some salt chipping. That will my first try at that technique so should be interesting.
          The picture of the wheels is because they are painted in Tamiya rubber black instead of plain old matt black, I don't know how many of you guys use this rubber black paint I don't know if I can spot much difference, what do you think?
          Next is one more light coat of grey on underside then salt chipping,
          Michael
          [ATTACH]59288.IPB[/ATTACH]
          [ATTACH]59289.IPB[/ATTACH]
          [ATTACH]59290.IPB[/ATTACH]
          [ATTACH]59291.IPB[/ATTACH]
          [ATTACH]59292.IPB[/ATTACH]
          • Vaughan
            • Apr 2011
            • 3221
            #35
            Some nice pre-shading Michael, it's really coming together.
            • Dave W
              • Jan 2011
              • 4713
              #36
              Looking good Michael.Thats a very neatly painted wheel.You must have a very steady hand.
              • yak face
                • Jun 2009
                • 14242
                • Tony
                #37
                Looks excellent michael , top work , cheers tony
                • michaelm
                  • Dec 2011
                  • 437
                  #38
                  Got a bit more done this evening, stuck some different size salt crystals to the model with water then gave the top of the plane a coat of Tamiya XF 13.
                  I made sure the surface was completely dry by giving it a light pass with the hair drier. I'm not sure about how this is going to come out and am beginning to wish I'd done a test....too late for that now, I'll let the paint dry completely then brush off the salt.
                  Keeping my fingers crossed, M
                  [ATTACH]59336.IPB[/ATTACH]
                  [ATTACH]59337.IPB[/ATTACH]
                  [ATTACH]59338.IPB[/ATTACH]
                  [ATTACH]59339.IPB[/ATTACH]
                    will be interesting too see how this pans out,as i`m really interested in this type of chipping
                    mobear
                    • flyjoe180
                      • Jan 2012
                      • 12958
                      • Joe
                      • Earth
                      #40
                      Me too, and this is a nice build so far Michael.
                        • 22954
                        #41
                        Looking good so far Michael
                        • michaelm
                          • Dec 2011
                          • 437
                          #42
                          OK, rubbed off the salt. Some of the paint has discoloured, I think it is where the water was applied to stick the salt, I think it looks ok.
                          It's quite difficult I think to get the chipping at the right scale if you know what I mean, but the effect is great, it was also hard to know how much salt to sprinkle, practice make perfect I guess.
                          One thing I did not do was salt chipping to the propellers, I painted them way back when waiting on the P.E. I'm also unsure if the props are ali or wood, if wood of course I'll have to think again re weathering. Anyone got an idea what they are made of?
                          I'm going to put a gloss coat on now for the decals. M
                          [ATTACH]59360.IPB[/ATTACH]
                          [ATTACH]59361.IPB[/ATTACH]
                          [ATTACH]59362.IPB[/ATTACH]
                          • Vaughan
                            • Apr 2011
                            • 3221
                            #43
                            The salt chipping has turned out really well Michael. I have not tried this method of weathering but may in the future have you used acrylic paints?
                            • Alan 45
                              • Nov 2012
                              • 9833
                              #44
                              looking good :thumbsup:
                              • michaelm
                                • Dec 2011
                                • 437
                                #45
                                Thanks guys, Yes Vaugan I used Tamiya acrylics, I think it will take a few attempts to get this technique to work just the way I want it to but I really like it, it's worth a go for sure. M
