B-17G Flying Fortress 'Miss Demeanor' 1/48 Monogram
    he`s in standby mode lol
    mobear
      Wow, wow, wow........Trey, you should make a TV show...."Pimp my Fortress-Kit"......I'm very excited!!!!
      Stefan
      :respect2:
        Moving on to the wings I dealt with the intake areas using some sheet styrene . I really could'nt stand the thought of paying the high dollar for a resin Paragon kit on evil bay. Took about an hour a wing to make the mods so it was'nt too hateful.
        I used the inside curve of the wing to mark a template
        After some trimming and sanding got a decent fit
        Then added the top covers
        The finished mods look the part and I saved some dollars to boot
        Cheers Trey
        • flyjoe180
          • Jan 2012
          • 12668
          • Joe
          • Earth
          #139
          Awesome work Trey, just goes to show with a bit of ingenuity and initiative we can modify most things with the materials we have laying around.
          • Dave W
            • Jan 2011
            • 4713
            #140
            Some great work going on here.The resin superchargers are a big improvement on the originals.
              cant watch no more,the sadness of the closure is killing me lol,however the detailing is past first class
              mobear
              • Vaughan
                • Apr 2011
                • 3200
                #142
                Great work Trey that's just total dedication.
                  Joe ,Dave thank you both kindly.
                  Ole thanks ,I'll raise a toast as the glue dries
                  Vaughan thanks
                  Using the kit supplied Mills,the detail on them is quite good
                  Mounted up temporarily for a fit check
                  Dry fit of the major components,the wing roots are going to need some filler underneath. Was really hoping to have a good slip fit so the wings could be removed for shipping. I'll need a bigger box I geuss.
                  Got the bomb cart together ,not sure if it will go with the display yet.
                  • mossiepilot
                    • Jul 2011
                    • 2272
                    #144
                    Just got caught up Trey, and the detailing is absolutely awesome.
                    Tony.
                    • Vaughan
                      • Apr 2011
                      • 3200
                      #145
                      It's really coming together Trey, looking forward to the next update.
                        4 hours of filling & smoothing seams ,drilling open intakes and the wings are ready for paint
                        the areas on the engine nacelles and next to the intakes were the worst
                        You all have made your input about closing this up well heard and I discussed it with my friend whom I'm building this for and he has given the go ahead to open up some cutaway viewing areas for the interior. So what do you all think about this rough draft?
                          • 22851
                          #147
                          Hi Trey it looks like you have the sections with the most to see covered with the view points so i think it would be spot on but what are you going to use it would need to be as clear as glass to get the maximum viewing.
                          Great work on the wings also
                            • 18288
                            Zip ties. Brilliant!!
                            My suggestion regarding all that detail being hidden: Buy one or two of those digital picture frame things and fill them up with photos of the different areas that are hidden away once its all buttoned up.
                            The detail in this build is stunning!
                              if you could see my smile lol,i`m glad the world will se in to this one
                              mobear
                                So all that brilliant detailing perfection is going to be seen then .....
                                .....happy days
