SE5a CONSTRUCTION BEGINNING TO . . .
  • Greyhead
    • Oct 2004
    • 581
    #241
    I totally agree with the comments from David and Barry. I’ve used closed loop systems to good effect in the past; they are reliable and light bit do require careful installation and I think this may account for some of the difficulties I had. I originally intended it to be a “dummy” pulley / cable system and as such I wasn’t as fastidious with the initial installation of control horns, pulleys, etc. as a would have been for a “working” system and we all know that “you can’t make a silk purse out of a sow’s ear”; used as it was intended it works fine.
    I look forward to seeing the J1 develop, if you think I may be able to help with the instrument panel, or anything else, don’t hesitate to ask.
    • Greyhead
      • Oct 2004
      • 581
      #242
      The attachment points for the tail plane bracing wires are not bolted on from the outside but attached internally and they are substantial items that exit the structure at acute angles, which would make covering after fitting quite awkward. To get around this problem I incorporated brass tubes into the TE and spar, after covering I passed a brass rod through the tube, soldered the attachment lugs to it and then bent it to the required angle; at this point the attachments were actually free to rotate. To check the angles were correct, and alter the ones that weren’t, before finally fixing them with a drop of cyano I rigged the tail plane using cotton.
      Well it’s that time of year again when it’s considered antisocial to spend half the day down the shed building; people to visit, people visiting etc. so I’ll have to content myself with some “quick build” items.
      Although C1096, upon which I’ve based the build so far, doesn’t have a headrest my model will as I think it is a quintessential part of the SE5a so this has been my first “quick build”. First a frame from 1/16th balsa and 1/32nd balsa skin.
      Then cover with litho plate.
      Finally glue in position.
      Once the glue’s set I’ll add the frayed tapes over the joints; she’s looking more like an SE5a every day.
        I think that Grahame's approach is sound for another good reason. Having part of a model built gives motivation to do the next part. Without this,
        a project can stay in the planning stage for ever.
        • Greyhead
          • Oct 2004
          • 581
          #244
          “Quick build” project 2 is the Vickers machine gun; about ½ the barrel protrudes from the gun cover and only the rear and right hand side of the stock is visible but I’ve decided to build a complete unit. The extra weight will be negligible and in the event of an untimely end to the SE5a it may be salvageable as a useful item.
          The barrel cover is 1/64th ply, soaked with ammonia and bent around 1/32nd ply formers that are temporarily mounted on piano wire to keep things aligned.
          The outer skin is litho plate embossed using an old ballpoint pen with the louvers cut and eased out using a scalpel.
          The barrel is aluminium tube and the flash suppressor plastic. The whole lot is painted matt black.
          The trick now is to take a soft pencil, I used a 9b but anything from 4b upwards is OK, and scrape the “lead” to make some graphite dust, apply this and then carefully burnish with a lint free rag. The resulting finish is a perfect “gunmetal”.
          • wonwinglo
            • Apr 2004
            • 5410
            #245
            A tricky item to make convincing,but you have achieved a remarkable result using that favourite standby Litho plate.
            If you need graphite dust then locksmiths sell bottles,I have just lubricated the rear car door with it,it has the advantage that it is not messy or gummy and will not freeze up,great for burnishing or weathering on scale models.
            For smaller Vickers guns check out those ladies hair curlers for modification ! we need to look everywhere in scale modelling.
            • Greyhead
              • Oct 2004
              • 581
              #246
              Continuing with the Vickers; here are the basic parts for the stock; the sides are 1/64th ply and the core ¼” balsa.
              The “eject side” has an 1/8th lite ply spring cover. You can see the rivets, which were embossed from the reverse side using an old ballpoint pen as for litho plate
              The ammo feed shoot is aliminium
              It now needs 3 coats of sanding sealer and painting before adding the various levers.
              • Greyhead
                • Oct 2004
                • 581
                #247
                The top covers are from litho plate but the levers need more strength so are cut from a “bean tin”.
                The “eject side” having had the matt black and graphite treatment, which really brings out the rivet detail. The extension at the rear is the connection from the interrupt system and will have a copper pipe attached
                The levers are pivoted using cut down pins and a 14BA nut and bolt, the handle is stained spruce.
                The Vickers has proved to be the ideal “quick build” for this Festive Season consisting as it does of several small parts; I have been able to disappear down the shed for relatively short periods thereby keeping the peace but still managing to do some meaningful modelling.
                • wonwinglo
                  • Apr 2004
                  • 5410
                  #248
                  Ah ! good old bean tinplate,we used to make those V-Wedge control line fuel tanks from this material,another good source of flat tinplate for free is those OXO tins.
                  Glad to see that you have integrated these small S.E.5A accessories into your building programme Grahame,albeit with breaks in the Christmas family environment
                  • Greyhead
                    • Oct 2004
                    • 581
                    #249
                    That takes be back a few years!! I well remember standing by the gas cooker waiting for the “magic moment” when the flame turns green. It is a real skill to be able to solder a leak free tank with a soldering iron that is constantly changing temperature.
                      You sure do enjoy using that litho plate! I'll have to look out for some, it looks like a great material to use. That vickers is really shaping up nicely, good use of graphite to give it a burnished steel look too.
                      • Greyhead
                        • Oct 2004
                        • 581
                        #251
                        Talking about tinplate tanks reminded me of an episode from my youth; I went to Apex Models in Leicester (was it in Church Gate?) and there was a ready-made tank and I remember thinking “Why would anyone spend that much money on something you can make yourself?” It was probably about 15p in today’s money but then again I only got 2/6d a week spending money!
                        To this day I still prefer to make rather than buy but the motivation is different. Take for example the Vickers that I’ve been working on over Christmas; I could have easily afforded to buy a plastic kit, which may well have produced a more accurate replica albeit probably not at 18% scale, but I wouldn’t have got half the sense of satisfaction that I got building from scratch.
                        Here are a couple of photos of the finished article.
                        An added bonus is the fact that it was built entirely from the “scrap box”, they don’t come much cheaper than that!
                        Alan
                        Just go your local printer and do a bit of grovelling, it works for me!
                        Grahame
                          What kind of ammunition feed will this Vickers have? Was it by means of a belt or did it have a circular magazine ontop a bit like a lewis gun or something?
                          I was googling for images but only came up with the land based variants of the gun with belt feed.
                          Found a super 3D computer model of a Nieuport though which is very nice though - which I thought you might enjoy!
                          More images are on the CG Society forums here:
                          • Greyhead
                            • Oct 2004
                            • 581
                            #253
                            There were many variations of Vickers, mainly with the barrel cover and trigger / lock mechanism. Some had 1 or 2 sets of louvers some had none; some had flutes some had none and some of the ground based ones were water-cooled. The firing mechanism had to be altered for the plane-based models to enable it to be cocked and later for the interrupt system, but as far as I’m aware they all used belt feed.
                            In the case of the SE5a there is an aluminium magazine just in front of the instrument panel and the ejected cartridges exit via a hole in the gun cover. Just how I’ll model the belt with all those cartridges I’ve no idea.
                            One thing I’ve discovered whilst researching this project is that there appears to be no such thing as a “standard SE5a”; possibly straight from the factory but once in the field many were modified by the ground crew and there was a lot of “cannibalism” to keep the aircraft serviceable, a later version could easily have an older undercarriage fitted or even a complete wing!
                              It's quite an education watching this thread, really gets an idea of how the SE5A was put together.
                              I'm sure you'll find a terrific way of modeling that ammo belt!
                              A lot of the Vickers Guns have a sort of brass fairing for guiding the ammunition into the gun, is that something that'll feature on your model?
                              • Greyhead
                                • Oct 2004
                                • 581
                                #255
                                Because the Vickers takes up most of the space under the gun cover a built up structure is impractical and the cover itself can only be thin so I decided to use my least favourite modelling technique; a fibreglass moulding.
                                For a “one off” I won’t bother making a female mould so first a slightly undersized balsa plug is made, using the piece of decking I removed as a base, filled and sanded smooth.
                                The plug is then covered with cling film; a useful thing about cling film is that it is in fact to some degree heat shrinkable so it’s relatively easy to get it to conform to the double curves. Then the first layer of glass cloth and resin is added, the only glass cloth I have is very lightweight “wing skinning” woven mat, so several layers will be needed to build up the strength.
                                Whilst waiting for the resin to cure I remembered that a few years ago my brother give me an off cut of coarse carbon fibre matting, quite loose woven so ideal for forming around double curves, just one layer of this should be sufficient. But finding it was no easy task; somehow it had managed to fall down the back of the shelf, fold itself in half and hide behind a cardboard box, if it had stayed where it was put I’d have seen it when I got the fibreglass cloth out and saved myself a lot of trouble!
                                The fibreglass was removed and replaced with carbon fibre.
                                Don’t ask me why I didn’t just leave the original fibreglass in place and put the carbon fibre over the top; I put it down to euphoria about not having to do all those extra layers and too much Christmas spirit (most probably in the reverse order!!).
                                After leaving to cure overnight the edges are trimmed, the front cut away and the slot for the cabane bracing wire cut. I’ve used carbon fibre tows to put 3 “ribs” on the inside to really stiffen the whole lot up.
                                Finally a shot of the Vickers in position showing just how little in actual fact is visible from the outside; the stock is partially visible viewed via the cockpit opening and the inspection hatch.
