Stinky,smelly fibreglass who wants it ! but no in this case it suffices to form the desired little cowl.
If anyone hates this stuff as much as myself then try this-Make the former exactly as Grahame has done,use the cling film technique as well,then soak brown paper strips in water,remove and cross layer using PVA adhesive as the resin,bake in the oven for a few minutes and ease from the plug,result one pattern that has not harmed the atmosphere and not stunk the place out.
You can even use blue foam as the plug,use the brown paper and when dry scoop out the foam with a potato peeler,told you that I was domesticated ! just an idea as a practical alternative to glass fibre.
