Graham, you're obviously well on your way with this but if you decide on a differrent direction I would have a play with a model yacht sail winch. You could use that to pull in a wire that operates a slide with some sort of release mechanism attached.
The beauty of a sail winch is that you have a lot more travel to play with than you do on a normal aircraft servo.
