To clarify things, when I said "now is the time to change the title of this thread by substituting "END" for the last 3 dots" I meant I’ve finished the construction section of the thread, not that the thread itself has come to the end. From now on, as well as the more mundane task of actually fitting out the model ready for flight, I’ll be adding / improving some of the detailing that I didn’t bother with earlier. Then of course there’s the flying!
The Lewis gun is very prominent, mounted as it is on top of the wing, so I thought that the magazine strap, which I’d made from masking tape, let the job down a bit. I still had some of the "thinned down" leather I’d used to make the cockpit edging so I decided to make a leather strap, complete with brass buckle.
The buckle was very easy to solder up from thin brass rod, but I think it really finishes the job off and was well worth the little time and effort it took. It was so easy in fact that I did the same thing to the "spare" magazine, which is just about visible through the fuselage window if you look very carefully.
