Tamiya 1/12 Yamaha YZF-R1
  • lachontrack
    • Nov 2019
    • 75
    #16
    Got some more of the painting done, first time with the airbrush. primed and painted, had to spray over my initial attempt on the nose cone with a humbrol spray can. in retrospect i should have assembled it all, primed and then painted to ensure a nice finish. learning curves!
      • 19065
      Hi Lachlan
      Looking good so far. Hope you’re enjoying it. If you need to, you can improve the spray finish by allowing the paint to gass off for a few days (basically dry right out) and then polishing the part with T cut or Tamiya polishing compound.
      • lachontrack
        • Nov 2019
        • 75
        #18
        Hi Lachlan
        Thanks, Tim! I may try that if another light coat doesn’t improve it.
          Coming along nicely Lachlan :smiling3:.
          • lachontrack
            • Nov 2019
            • 75
            #20
            Thanks mate!
            • lachontrack
              • Nov 2019
              • 75
              #21
              update on the engine block! i airbrushed the three new parts added, what a difference it makes! it’s just a shame that the rest of the hand brushed work is so shoddy:tears-of-joy:
                Looks ok to me Lachlan :smiling3:.
                Who cares about shoddy?. Just have fun.
                • lachontrack
                  • Nov 2019
                  • 75
                  #23
                  Cheers! I am having fun, I just wish I’d started with an airbrush! I have a couple of kits in storage whilst I work on my technique, as I want them to be quality :tears-of-joy:
                  • Bortig the Viking
                    • Mar 2019
                    • 780
                    #24
                    Hi, if you want to start the engine again, although what you've done looks good, you can always use VMS Clean slate, works a treat used it myself. I found that knowing you can rewind the painting it makes it easier to do, not so daunting.
                    Have fun, that's the main thing.
                    • lachontrack
                      • Nov 2019
                      • 75
                      #25
                      Thanks, Bortig! I’ll look into it maybe, I don’t think it looks too terrible anyway.
                      • lachontrack
                        • Nov 2019
                        • 75
                        #26
                        job for tonight : continue on with the engine. this part involves lots of fiddly painting. i’ll probably prime all the parts first, then handpaint them. the journey continues!
                        • lachontrack
                          • Nov 2019
                          • 75
                          #27
                          slowly but surely getting there. need a coat or two extra on the primer but looking good otherwise! knocked over the bottle of vallejo black primer last night and it went EVERYWHERE. luckily enough it gave the first coat time to dry as i cleared it up!Click image for larger version
ID:	1110705Click image for larger version
ID:	1110706Click image for larger version
ID:	1110707Click image for larger version
                            When it says surface primer it didn't mean the surface of your desk:tears-of-joy:.
                              Lachlan,
                              been there, done that! I've some abstract green patches under my workbench.............
                              Now, if I'm brush painting, I use a pallet, and if I'm on the airbrush, I use plastic shot glasses to mix up the correct consistency - At no point is an open paint pot ON my bench, it's only open in my hand. If I have an accident, it's only a small amount that needs cleaning up...............
                              • lachontrack
                                • Nov 2019
                                • 75
                                #30
                                cheers! aye, i realise that now, had to get some on the floor as well just for good measure :tears-of-joy:
