Mirror Models Bulldozer.
    Andy those tracks are very similar to the Stalin version, your doing well with their assembly.
    • Lee Drennen
      • 7738
      #77
      Andy. Mr Race is on his mark when he said the track looks good your doing a great job with this
        Originally posted by outrunner
        Then when fully set just click them together.
        That is very good to know. I think I would have tried putting the links together before the glue sets, but if they will go together after the glue dries, things should be much simpler.
          • 19104
          Nice work on the track parts.
          • outrunner
            • Apr 2019
            • 2420
            #80
            I may try that method with the other track as the one I have done has developed a distinct curve, not that it matters as they will be glued on so I will be able to eliminate the curve.
            Andy.
            • Steve Jones
              • 6615
              #81
              Nice work on the tracks Andy. Looking forward to seeing all the dried out mud on those bad boys.
              • outrunner
                • Apr 2019
                • 2420
                #82
                It has been too warm of late to get much done in the workroom the last few days so I spent a lot of time (and petrol money) on the bike. I have just been doing little bits here and there but it will get there in the end.
                Fitting all those levers/pedals and the PE floor was a load of fun.
                [ATTACH]392593[/ATTACH]
                [ATTACH]392594[/ATTACH]
                Test fitted the blade to see how it will look.
                [ATTACH]392595[/ATTACH]
                [ATTACH]392596[/ATTACH]
                Obviously a lot more paint needs to come off the blade and some other parts to get the right effect.
                Andy.
                  • 22954
                  #83
                  Just caught up Andy, Looking very nice
                  • outrunner
                    • Apr 2019
                    • 2420
                    #84
                    Slowly, very slowly, getting there with this model.
                    [ATTACH]392837[/ATTACH]
                    Have to be careful not to touch any of the fragile bits like levers and pedals that will break if you look at them the wrong way.
                    [ATTACH]392838[/ATTACH]
                    [ATTACH]392839[/ATTACH]
                    Next thing will be to try the system I have come up with to make the overhead blade actuating system removable as I have an idea for another use of this model.
                    Andy.
                      Good and grimy. Great work Andy.
                      • outrunner
                        • Apr 2019
                        • 2420
                        #86
                        Thanks Peter, a lot more dirt/grime is needed to finish the model off.
                        Andy.
                        • outrunner
                          • Apr 2019
                          • 2420
                          #87
                          In order to make the blade mechanism removable I had to replace the rather flimsy plastic channel that carries the cable from the winch to the blade with a bit of brass tube I had, not exactly scale but it will do.
                          And removed.
                          The front frame hangs on 2 pegs below the radiator and the supports are supposed to be glued to the side frames but I just used a couple of small screws. Possibly a bit agricultural but they will never be seen behind the tracks.
ID:	1129188 The rear support just sits in a couple of brackets from my spares box glued on to each side of the winch.
                          Now I need to figure out how many strands of fine wire I need to twist together to make a winch cable as all the kit provides is a bit of thread, Really?
                          Andy.
                          • Gern
                            • 9301
                            #88
                            Brass picture wire might do for your cable Andy.
                            • Steve Jones
                              • 6615
                              #89
                              My latest kit had a piece of frayed string for the tow cable LOL. There are a few threads on the forum on how to make your own or buy one on the tinternet. The dozer is certainly looking the business
                                • 16165
                                Hi Andy
                                Looking good. Also looks very, very fragile.
