My first ever building ( scratch built )
  • Robert1968
    • Mar 2015
    • 3596
    #16
    Originally posted by \
    Robert, with you deciding to use such very thin plastic card, you will find it will probably warp as you are cutting out the openings.
    To get over this, once you have completed all the cutting on the face, turn the piece over and gently scour random cuts (more like heavy scratches) on the reverse side. This will straighten out your wall.
    I hope this little tip will be of some use to you.
    Ron
    Thanks Ron for the tip.
    Regards
    Robert
    • monica
      • Oct 2013
      • 15169
      #17
      coming along nicely ,always alot of work,
      as I find it takes a long time to cut out the card,also if you drill a hole in the corner lets you get into that spot without,
      going over your lines,
      and that's why I use cardboard,as I like the use of my fingers,
      • Robert1968
        • Mar 2015
        • 3596
        #18
        I hate to say this Monica but I just read your post as I was putting plaster on my thumb ( surprised myself on how deep a No 10a scalpel will in bed in your thumb( ouch ( yes I did swear a little )
        Robert
        • spanner570
          • 15594
          #19
          Robert, I hope you've saved the spilt blood - you can use it to weather your brickwork! :P
          • Robert1968
            • Mar 2015
            • 3596
            #20
            You know what I wanna do right now with your name Spanner!!!! ( swing it in your general direction!!!! Hahahahahhaahahah
            I can't believe how much that bloomin hurt too but luckily I'm a first Aider and I patched it up no problem!!
            Robert
            • monica
              • Oct 2013
              • 15169
              #21
              Robert
              oh ouch,
              well I have not done much over the last week,from having done the same thing,and two fingers are still a little numb.
              plus doing cleaning around the hose,
              was taking the cover off the blade to clean paint of the window,and it poped off then sliced my hand open,and I tell
              you I,did swear a lot lol.
                I learnt a long time ago that these sharp things we use can bite back. I have a one inch scar on my right thumb after being a numpty while taking off some mould seams off a figure. Yes it bled a lot and yes I swore a lot also.
                  Scalpels are designed to cut flesh and they do it so well lol. Trouble is, the blades are so fragile and snap so easily. Might be better with a scribing tool or Stanley knife for the heavy stuff.
                  • Robert1968
                    • Mar 2015
                    • 3596
                    #24
                    Oh I love the Stanley ( not) now I'm not saying I'm careless as I'm not but don't know if you know in the standardStanley you get a hooked blade for cutting carpet ( well few years ago went through the carpet as you do cutting away and straight into my knee ( nice scar there now.....
                    We should do a damage thread!! The dangers in Modelling!!
                      Nice claret coloured trousers and carpet then.
                        Have you thought of taking up knitting Robert? Oh, hang on pointed needles
                          sounds as though he might get himself tied up or get the needle trying knot to
                          • Pikeman
                            • Feb 2016
                            • 1312
                            #28
                            well I've decided after watching Ralph's build to build my own building for my ""out of gas out of time"
                            I'm going to build a simple 2 storey townhouse which will have some damage to the roof walls and floors.
                            It's going to be my first ever scratch building but with Ralph's advice and help I think it could work
                            I'm using 2mm plastic card ( got 6 sheets in a deal) and I got Tamiya brickwork transfer.
                            I've used the 9mm to 1ft scale which should be 1/35.scale
                            I have ref pics to work from
                            Comments welcome
                            [ATTACH]147604[/ATTACH] [ATTACH]147605[/ATTACH] [ATTACH]147606[/ATTACH]
                            Good luck Robert I hope it all goes to plan and I will be watching the progress as the build comes together.
                            Always wanted to see a scratch build from the start
                            • Gern
                              • 9273
                              #29
                              Robert
                              Your sacrifice to the Gods of Modelling Robert. You have to do this to become a fully fledged member of our congregation!
                              • Robert1968
                                • Mar 2015
                                • 3596
                                #30
                                Now who would have tho ught a stanly could do the job in half the time ( not me that's who ) but it works a treat and no more broken scalpels ( buggers are so fragile with a bit of pressure )
                                Thanks graham for the tip
                                Regards
                                Robert
