My first ever building ( scratch built )
  • Robert1968
    • Mar 2015
    • 3596
    #46
    Thanks Terry. When I first started this I was quite unsure of what I was doing but I've had a good start and with help and guidance I'm rather enjoying the build ( learning lots too
    Robert
      It really is good seeing this come along.
      • Robert1968
        • Mar 2015
        • 3596
        #48
        Originally posted by \
        Nice progress Robert. Who Si Dawn by the way?
        Just to confuse you more Graham my wife's called Alison!!
        • Robert1968
          • Mar 2015
          • 3596
          #49
          Thanks for the kind words Ralph, if it goes all pear shape we know who's to blame..... ( me!!
          • Robert1968
            • Mar 2015
            • 3596
            #50
            Well that's the window frames nearly finished I'm going to double up on the tops and bottoms and sorry to pinch Ralph's idea I may even put some decorative parts on the outer frames.
            The inner frames be got some evergreen strip styrene but I'll do some measurements before I fit.( bit tricky me thinks but I'll get there. Still got the windo sill to do aswell
            I put a corner of roof beam on side to see the roof hang
            I'll have to make guttering and drain/ down pipes too ( need to source this or scratch build from something.
            Comments and advice most welcome
            Pics
              I reckon you have done this before Robert
              This is coming along real well and I bet you are getting a real buzz from doing this.
              • Robert1968
                • Mar 2015
                • 3596
                #52
                The only building I have ever made was the Pegasus bridge wooden model/ card kit not that challenging
                Regards
                Robert
                • spanner570
                  • 15594
                  #53
                  Looking good Robert.....I might be a bit late with this suggestion, but don't double up top and bottom - just the window cills. It doesn't matter that much, but the cills usually stick out more than the top stonework.
                  • Robert1968
                    • Mar 2015
                    • 3596
                    #54
                    This as my last building but it was laser cut wood and just pop out and sand and wood glue together. Think it's more for war gaming but my wife bought it fo me once we visited it a few years back. A simple build but the bridge was quite intricate. So this will be my furst scratch build ( thanks for the ref guides Ralph and your continued support
                      That's a nice little kit in it's own right
                      • Robert1968
                        • Mar 2015
                        • 3596
                        #56
                        Spot on that man Ron ( I thought about doubling up the wood on the top sills as well but then thought nah that wouldn't sit right especially with the ledges to go in would look silly.
                        I will be giving the brickwork some artexing of a kind ( want a few cracks and debris also some bullet holes in the brickwork.
                        Regards
                        Robert
                        • monica
                          • Oct 2013
                          • 15169
                          #57
                          looking good do like your progress,well done so far,
                          ta for the info ,on the brick sheet,
                          do know of a guy over hear who dose laser cutting and have asked him 3 times about making brick wall sheets and doors and windows
                          but he just has not answered,
                          • Robert1968
                            • Mar 2015
                            • 3596
                            #58
                            Well little update
                            After chatting with Ralph I decide to put the two pieces together and think it's not a bad old fit ( there will be rendering so this will hide the joint.
                            I started on the upstairs flooring and this has been acheived by drilling pilot holes in the front beam and inserting skewers ( I'll trim these later ).I straightened out and trimmed some coffee stirrers which will represent floor boards. It is a suck it and see but I think it's not too bad. I coated the whole floor in PVA thinned with water to see if it will join all the pieces together ( later they will be painted and weaterhered.)Once the ground floor is similarly done I'll start on the dividing walls then roof ( that's gonna be fun )
                              The floor boards look great.
                              All uneven like they should be.
                              • Robert1968
                                • Mar 2015
                                • 3596
                                #60
                                Thanks Ralph. I think this is going well, there were a few fit issues( hahahahaha ) but I'm still enjoying it.
                                Regards
                                Robert
