Golan patrol
  • Snowman
    • Oct 2014
    • 2114
    #76
    That is one of my all time fave MBT's, you have done it justice!! :x
      thanks snowman merkava my favourite as well.
      scott
        thanks si
        Scott
          • 22983
          #79
          I really like the Merkava and you've done a fantastic job on this one Scott.
          • dave
            • Nov 2012
            • 1844
            • Brussels
            #80
            Originally posted by Fenlander
            Ahhh, is this the paper covered foam core? I use that as a base material.
            Lots of YouTube videos show an uncovered foam that can be carved or scribed. I assume this is a high density foam like insulation but I don't know if it is available in thin sheets.
            Graham,
            With a little water you can remove the paper from one or both sides and emboss it.
              thanks papa glad you like it, the kit is a cricking build the only ball ache is the chain and ball armour underneath the turret. Dave if you gently heat the paper up with a hairdryer it comes away without the need to wet it.
              scott
                thanks si.
                  Hi guys here is another update, iam in progress on building revells dingo, which will be painted in UN colours ie white. This is where iam up to with it, its been primed had to add a bit more filler.
                  scott
                  [ATTACH]254983.IPB[/ATTACH]
                  [ATTACH]254984.IPB[/ATTACH]
                  [ATTACH]254985.IPB[/ATTACH]
                  [ATTACH]254986.IPB[/ATTACH]
                  [ATTACH]254987.IPB[/ATTACH]
                    Nice work Scott.
                    This should be a great dio.
                      Nice work Scott.
                        thanks Ralph glad you like it, lots more to do.
                        scott
                          Hi all this is as far as iam going on with this tonight, tomorrow some tidying up and a bit of light weathering should do it.
                          scott
                          [ATTACH]254998.IPB[/ATTACH]
                          [ATTACH]254999.IPB[/ATTACH]
                          [ATTACH]255000.IPB[/ATTACH]
                          [ATTACH]255001.IPB[/ATTACH]
                          [ATTACH]255002.IPB[/ATTACH]
                          [ATTACH]255003.IPB[/ATTACH]
                          [ATTACH]255004.IPB[/ATTACH]
                          [ATTACH]255005.IPB[/ATTACH]
                            Great progress Scott, always fancied doing a UN vehicle.
                              thanks graham just need a humvee now.
                              scott
                                Hi guys and gals, the UN dingo is now complete, hope you like it and as always all comments are welcome.
                                scott
