Not a Moment to Lose… Battle of the Bulge, Ardennes, December 1944
  • TIM FORSTER
    • 297
    • TIM
    • LONDON, UK
    #181
    Bring on the vehicles...
    Sdkfz 250/1 Ausf B 'Neu'
    I have to admit that I have long had a soft spot for the Sd.Kfz 250 and the late Ausf B version in particular. It tends to be overshadowed by its much larger cousin the 251, but with its short length and snub nose there is something almost cute about it!
    When I was last modelling back in the 80s, when the only kits available were the early Ausf A versions by Tamiya (notably Rommel’s famous ‘Grief’ 250/3 variant with the frame antenna), I even contemplated a partial scratchbuild. Luckily in 1998 Dragon finally got around filling the gap.
Name:	20211219_152841 close up.jpg
    The kit I used was actually the Dragon 250/8 which I found second hand at IPMS Scale Model World in Telford a few of years back. Since the kit also includes all the parts for the original 250/1, this didn’t matter (apart from the decals as I later found out).
    I also sourced some photoetch from both Royal Model and Aber. Some people hate PE and, if I am honest, I would rather avoid it - but sometimes there is nothing that looks as good. I usually buy two sets from different manufacturers so that I have more than one choice when it comes to tricky parts: there’s usually one that’s easier or simpler (and it’s almost never Aber).
    The one place where I think all of the late model 250 kits let themselves down is on the upper side armour. This is far too thick. The real vehicle actually had fairly thin side plates bolstered with internal armour panels. The side vision slits are also poorly defined.
    For this reason I highly recommend the Aber set. This is actually etched into thicker metal than their usual sets and it fits the Dragon, etc kit parts really well. The only minor surgery required is to separate the old upper armour from the bonnet.
    Opened-topped vehicles are always a challenge because there is so much detail and nowhere to hide, but the late 250 is also very crowded.
    Surprisingly there is also a lack of reliable information about what the interior actually looks like. For a vehicle that was built in the 3,000+ range there are remarkably few surviving examples of the late 250/1 variant and those that I have found on line are often heavily restored. There are a lot of fine factory interior shots of the early (Ausf A / ‘Alt’) versions of the 250 taken by the Germans during manufacture, but none for the later model. Perhaps they didn’t bother keeping these sorts of meticulous records later in the war (they had other things to think about) - or the archives are now lost. Two useful reference books are:
    Panzer Tracts No.15-1: Le.s.p.w. (Sd.kfz.250) Ausf.a & B by Hilary Doyle and Thomas Jentz, and Sd. Kfz 250 Alt-Neu: Archive: v.3,Pt.2 by Martin Kogel.
    Fortunately, the first has re-printed and whilst the second is OOP, but can be found fairly easily second-hand.
    They each have a lot of excellent photos and the Doyle/Jentz book has fine scale drawings of most variants, but they both leave the interior of the late 250 as something of a mystery. The Doyle/Jentz book has a plan view of the late 250/3 with interior, for example, but the plan view of the 250/1 has an empty interior. Knowing the authors, I suspect this is because they were not prepared to speculate where they lacked enough first-hand source material.
    Anyway, I didn't want to get too bogged down in the technical stuff - this is supposed to be a diorama blog after all. In the end, what I put together was based on the original Dragon kit, a mixture of the Aber and Royal Model photoetch sets (which often overlap, but sometimes differ), the above-mentioned books and images I found on line. Chief amongst the latter were pictures of the well-known Panzerfarm late 250/1 that was dredged up from a river surprisingly intact.
    Because the upper and lower half of the superstructure need to be attached before you can complete the exterior I did most of the interior painting before this happened. At this stage I also added a driver using parts from various figures. Getting this guy to fit was one of the most challenging parts of the build because the fit is so tight: once he was in he wasn't coming out!
Name:	PXL_20250406_114308837 redux.jpg
    • scottie3158
      • 14634
      • Holbeach
      #182
      Stunning
      • Airborne01
        • Mar 2021
        • 4361
        • Steve
        • Essex
        #183
        Superb modelling, the detail and weathering is outstanding!
        • Neil Merryweather
          • Dec 2018
          • 5351
          • London
          #184
          Wow Tim, that's brilliant!
          • minitnkr
            • 7806
            • Dayton, OH USA
            #185
            Amazing.
            • TIM FORSTER
              • 297
              • TIM
              • LONDON, UK
              #186
              Thanks guys...
              Sdkfz 250 Ausf B Part II
              A few views of the exterior before the paint hit...
              Click image for larger version  Name:	PXL_20250425_141528679.jpg Views:	0 Size:	268.7 KB ID:	1265606
              Click image for larger version  Name:	PXL_20250425_141837603.jpg Views:	0 Size:	177.4 KB ID:	1265608
              Click image for larger version  Name:	PXL_20250425_141746211.jpg Views:	0 Size:	185.5 KB ID:	1265607
              You can see the muxture of photetch from Royal Model (the brass and resin exhaust), Aber (the upper superstructure and MG shield) plus a few additions of my own (like the side step). The beautiful sagged front wheels are from DEF Models and the sprockets are 3D prints from SBS (the same people who provided the seats and radio). The crisp side vision port slits are a very nice feature of the Aber set - you just don't get this with the original plastic.
              I textured the upper hull sides and the armoured nose with diluted Mr Surfacer 1000 to give the appearance of armour plate.
              The tarpauline still needs a little more work but I’m happy that I went with the old-fashioned tissue and PVA glue method. It sits on one of the metal hoops from the Aber set and it’s fully detachable.
              Here's a nice shot of the Panzer Farm 250 for comparison: not looking bad for a vehicle which spent several decades in a river!
              Click image for larger version  Name:	Panzerfarm.jpg Views:	0 Size:	198.2 KB ID:	1265609
              Painting started with an airbrushed coat of Mr Surfacer 1000 Mahogany followed by Tamiya Dark Yellow 2 XF-80. This is the ‘improved’ acrylic version of the classic German Dunkelgelb (RAL 7028). I had not used my airbrush for a while and I forgot just how beautifully these Tamiya paints spray. After that I lightened the mix in two stages with some white and went for light overspray in a random cloud pattern, focussing on the highlights. I then finished with a coat of Semi-Gloss X-35.
              Click image for larger version  Name:	PXL_20250501_152357415.jpg Views:	0 Size:	161.7 KB ID:	1265610
              Click image for larger version  Name:	PXL_20250504_133759744.jpg Views:	0 Size:	149.3 KB ID:	1265611
              At this point I hadn't given much thought to how I was going to finish the halftrack beyond the standard dunkelgelb. Should it stay in the basic colour or be camouflaged?
              Click image for larger version  Name:	250 at Kaiserbaracke Crossroads close up.jpg Views:	0 Size:	54.3 KB ID:	1265612
              Looking closely at the 250 from the famous newsreel taken at Kaiserbaracke Crossroads (these two characters both appear in the iconic close-ups of of the Schwimm taken during the same sequence) you can see that the nose plate has the distinctive camo pattern. Also note what you can’t see - the SS runes are not visible on the number plate. This is not internet censorship: Kampfgruppe Hansen deliberately painted over the runes to disguise the fact that they were part of the 1st SS Panzer Division LSSAH.
              The standard three-colour scheme is clearly shown in images of factory-fresh 250s taken in 1944. These are from the excellent Panzer Tracts 15-1:
              Click image for larger version  Name:	250 in factory applied camo 3.jpg Views:	0 Size:	85.5 KB ID:	1265613
              Click image for larger version  Name:	250 in factory applied camo 4.jpg Views:	0 Size:	166.8 KB ID:	1265614
              Once again I went with Tamiya acrylics, this time Dark Green 2 XF-89 and Red Brown 2 XF-90. Reminding myself to keep the air pressure as low as possible (around 5 psi), the paint as thin as possible (using Tamiya orange cap retarder lacquer thinner way beyond the 50% ratio) and the nozzle close to the model, I started…
              Here is the outcome of my first attempt.
              Click image for larger version  Name:	PXL_20250510_102946452.jpg Views:	0 Size:	409.8 KB ID:	1265615
              Click image for larger version  Name:	PXL_20250510_103024754.jpg Views:	0 Size:	391.3 KB ID:	1265616
              At first, that I was quite pleased with the results. Sure, there was plenty of blotching and some spatter here and there - but in the real world this was applied with a spray gun by someone in a hurry… not an artist. However, comparing it to the reference images I decided that it just looked too ‘artistic’: the gaps between the squiggles were too regular and the squiggles themselves too narrow. So I took a deep breath and had a second go, adding to what I had already laid down.
              This time I was much happier with the way it turned out.
              Click image for larger version  Name:	PXL_20250510_154613678.jpg Views:	0 Size:	330.0 KB ID:	1265617
              Click image for larger version  Name:	PXL_20250510_154555842.jpg Views:	0 Size:	154.4 KB ID:	1265618
              Click image for larger version  Name:	PXL_20250510_154522581.jpg Views:	0 Size:	157.8 KB ID:	1265619
              The decals, by the way, were found after a long dig through my spares box. The information stencil comes from a Fiat Topolino... Yes, I know it's not correct, but it was all I could find. However, everything will soon be covered in foliage and the port side will be almost invisible once on the diorama, so to hell with it!
              • TIM FORSTER
                • 297
                • TIM
                • LONDON, UK
                #187
                Sdkfz 250 Ausf B Part III
                These photos below show the halftrack after I had added the wheels and tracks and (almost) finished the weathering process.
                In the image above the vehicle is only tempororily in place and it may look as if it is floating. However, as it was relatively light the tracks did not tend to sink into the ground as much as the heavier tanks, so I may not bed it in too far in the end.
                There is also going to be a lot of foliage added, so any small errors can be conveniently covered up!
                The weathering was mostly textbook stuff.
                I started with a wash of Abteilung 502 Brown Wash (over the semi-gloss finish) which was left to dry for a few days. After the wash, the model tends to look rather glossy and unreal, so I knocked this down with a light spray of Mig Matt ‘Lucky Varnish’. This stuff is great, because you can spray it straight out of the bottle and cleaning the airbrush has never been easier!
                This was followed by chipping. Rather lazily I started with Mig Light Wood - it’s just a decent lighter shade (a sort of yellow/grey) that adds contrast to all areas, whether they be the original dark yellow finish or the camo colours. This was partly done with the sponge technique, but mostly with a fine brush.
                It was then a matter of adding darker chips - some with dark grey to suggest chips through to the metal, others with red brown to represent shallower chips that only reached the primer coat. In a few places I then added a metallic element with Mig Gun Metal and a sharpened graphite pencil.
                Sorry I couldn’t be bothered to take step-by-step photos of this process, but I hope you get the general idea. Although you cannot really see it in these images, I also added dried and wet mud to the underside using a variety of Vallejo acrylic and Wilder products (the latter sadly no longer available).
                There’s still a little way to go, but I don’t want to finish the weathering process until I decide how dark to go with the terrain and - most importantly - how cold and damp I want it to look.
                Now on to the Schwimm!
                • scottie3158
                  • 14634
                  • Holbeach
                  #188
                  Very nice finish mate.
                  • TIM FORSTER
                    • 297
                    • TIM
                    • LONDON, UK
                    #189
                    So let’s have a look at the Schwimm…
                    This is the excellent Tamiya kit with a little helping hand from Aber and Eduard photoetch. As usual, I chose two PE sets to give me options for the easier route (usually not Aber), plus there are almost always some details missing from one set and present in the other. Another essential was the DEF Model sagged wide tyre wheel set.
                    I modifed the front suspension to allow the wheels to adopt a slight turn. It’s a relatively simple fix - and just looks more dramatic.
                    I ensured that I could keep this interior assembly detachable even when I had fixed the top and bottom of the hull together. It’s a tight fit, but just possible if you sand down the rear portion beneath the rear seats a little. Either way, you will have to paint the floor pan before you fit the duckboards or else you risk some of the raw plastic shining through… All the paint you see here is Mr Surfacer Mahogany sprayed through an airbrush.
                    One of the few issues with the Tamiya kit - but a big one - is the fit of the upper and lower halves (and here, at least, the word ‘hull’ seems appropriate!). My kit was slightly warped and, although the join would be invisible from the outside (because the running boards and mudguards hide it), it is is very obvious in the exposed interior. In the real vehicle there is a join here because the top and bottom halves are welded together, but in this scale it would be all but invisible.​
                    Here are some shots of the finished model before the paint went on. The figure was an early attempt at the driver, but I wasn’t happy with the pose so you will see him replaced in the later shots.
                    The only other part of the build that I found challenging was the fold-down top. The Aber set tells you how to make the supports from bent wire, but it looks like an absolute nightmare - and there’s still no tarp! The Tamiya moulded version isn’t bad, but it just looks too much like a lump of plastic. I hacked it about a bit and then added to it with Tamiya putty and some photoetch buckles and straps. In the end I still wasn't happy so after I had painted the model I went back and added a better tarp from tissue soaked in PVA.
                    Here's the Schwimm along with the 250 at the early painting stage...
                    • scottie3158
                      • 14634
                      • Holbeach
                      #190
                      Excellent work as always Tim.
                        • 19130
                        Really lovely work Tim. Excellent finishes on excellent vehicles.
                        • Neil Merryweather
                          • Dec 2018
                          • 5351
                          • London
                          #192
                          Loving this Tim, keep it coming!
                          • TIM FORSTER
                            • 297
                            • TIM
                            • LONDON, UK
                            #193
                            Thanks guys!
                            More shots of the (almost) finished Schwimm...
                            Click image for larger version  Name:	PXL_20250630_141234414.jpg Views:	0 Size:	388.5 KB ID:	1266877
                            Click image for larger version  Name:	PXL_20250630_141237739.jpg Views:	0 Size:	376.4 KB ID:	1266878
                            Click image for larger version  Name:	PXL_20250630_141223603.jpg Views:	0 Size:	414.4 KB ID:	1266879
                            The twin Panzerfaust were a a common feature the Kampfgruppe Hansen Schwimms passing through Kaiserbaracke crossroads on their way to the front.
                            I cannot make out any camouflage and going for the plain Dunkelgelb finish makes for a nice contrast with the 250 halftrack.
                            Click image for larger version  Name:	Either Obersturmführer Leidreiter or Goltz.jpg Views:	0 Size:	48.9 KB ID:	1266880
                            The Schwimm that was filmed first pausing at the crossroads sign is the one mine is based on. It was draped in foliage and In this sequence you can also make out the panzerfaust as it drives away. Note the clipboard and the different gloves being worn. The driver looks very young and wears a sidecap. The officer is, I believe, SS-Standartenführer Goltz (not SS-Obersturmführer Leidreiter as some sources claim).
                            Click image for larger version  Name:	Schwim at Kaiserbaracke Crossroads 1.jpg Views:	0 Size:	268.1 KB ID:	1266881
                            Click image for larger version  Name:	Schwim at Kaiserbaracke Crossroads 2.jpg Views:	0 Size:	285.9 KB ID:	1266882
                            Click image for larger version  Name:	Schwim at Kaiserbaracke Crossroads 3.jpg Views:	0 Size:	254.0 KB ID:	1266883
                            The reason my Schwimm is missing the drivers seat (and steering wheel) is because the driver is already in it!
                            Click image for larger version  Name:	PXL_20250309_135944518.jpg Views:	0 Size:	193.6 KB ID:	1266884
                            The putty creases make him look a bit of a mess, but, like all of my figures, he is awaiting a coating of Mr Surfacer to unite the finish before I hit him with paint.
                            He’s a kitbash of Tamiya torso, arms and legs (they look rather small but they won’t when he’s in the vehicle - and most importantly he fits), Alpine head and one Hornet hand (I used any old hand for inside the glove!)
                            • TIM FORSTER
                              • 297
                              • TIM
                              • LONDON, UK
                              #194
                              The Jeep
                              OK, so I'm going to take this a bit quicker so that we can catch up with real time on this diorama...
                              Click image for larger version  Name:	PXL_20250715_163758762.jpg Views:	0 Size:	221.3 KB ID:	1268356
                              Had I ever built a jeep before? I feel that I must have done back in my youth, but my only memory is of the old Tamiya Russian Gaz. So maybe not…
                              Click image for larger version  Name:	20221222_170248.jpg Views:	0 Size:	455.7 KB ID:	1268355
                              I started with the updated Tamiya kit. It’s nice that they actually licenced the name, so it’s not called something silly like a ‘1/4 ton Utility Truck’… it’s a JEEP!
                              When I started I knew almost nothing about Jeeps. Now I know a little bit more. The Tamiya kit is excellent, but there are little details that are either missing or simplified and here the Voyager PE set comes to the rescue. There are also many, many images available on line, so there’s really no excuse not to go to town adding them… the only problem seems to be that Jeeps are so numerous that finding the right bits for the correct period is difficult.
                              In my scenario the vehicle has broken down, so one aspect I wanted to include was an open bonnet. The engine is actually pretty nicely detailed in the kit and, although Voyager include some bits and pieces there are still a few more be added, such as wiring, battery terminals, etc.
                              Click image for larger version  Name:	PXL_20250628_131412184 crop.jpg Views:	0 Size:	180.0 KB ID:	1268357
                              Click image for larger version  Name:	PXL_20250628_131444335.jpg Views:	0 Size:	205.1 KB ID:	1268358
                              Stowage was added from various sources along with some tools on the fender to help tell the story (along with the open bonnet) that this is a vehicle under emergency repair. I also added the distinctive safety straps from Tamiya masking tape and PE buckles. Thse are so often missing from other Jeep models, but they were important: with no doors or seatbelts, you needed something to stop you falling out!
                              Two other important additions to the kit were new wheels and a canopy. Both came from resin after-market sets:
                              Click image for larger version  Name:	PXL_20250715_220016706.jpg Views:	0 Size:	318.7 KB ID:	1268359
                              The canopy by The Bodi is beautifully sculpted but the struts are too thick, lacking in detail and warped. So I replaced them with brass rod and added details from the Voyager set.
                              Click image for larger version  Name:	PXL_20250628_131412184 canopy crop.jpg Views:	0 Size:	60.5 KB ID:	1268360
                              Then it was on with the paint...
                              Click image for larger version  Name:	PXL_20250630_142311423.jpg Views:	0 Size:	148.0 KB ID:	1268361
                              This time I remembered to spray the brass with Mr Metal Surfacer. After an undercoat of Mr Surfacer Black for the base coat I used AK Olive Drab primer. This wasn’t the fancy 3rd generation stuff, just what I had, thinned with Tamiya Orange cap (retarder) and gradually lightened with Tamiya white for succesive oversprays. For the canopy I used # XF-14 Japanese Army Grey and a little Buff. I then gave everything a covering of satin varnish.
                              The decal sheet is pretty comprehensive and includes labels for the glove compartment and both fire extinguishers (the instructions call out brass for these, although I have also seen images of them in a dull grey colour - presumably late war). Strangely there are no decals for the dash, so I added the dials from the sheet I used for the Sdkfz 250.
                              The Tamiya set includes markings for a recce unit of the 814th Tank Destroyer Battalion, 7th Armoured Division. This is actually pretty handy for my diorama, since the figure I am going to position at the corner near the jeep is dressed in tanker’s uniform. Since the 814th TD Battalion was transferred to the Ardennes on 17th December and participated in the defence of St. Vith, it is theoretically possible that a recce unit found themselves in the path of an advance unit of the 6th Panzer Army. And if I am wrong about that? Well, by the time I had finished the weathering process there wasn’t much of the unit insignia visible anyway!
                              Click image for larger version  Name:	PXL_20250715_163700277.jpg Views:	0 Size:	223.9 KB ID:	1268362
                              • Steven000
                                Steven000 commented
                                Editing a comment
                                Lovely work Tim, cheers
                            • scottie3158
                              • 14634
                              • Holbeach
                              #195
                              That's a cracker Tim
