All I need is glue
  • BBdave
    • Aug 2014
    • 825
    All I need is glue
    I'm off to the model shop in the morning "all I need is glue" I have kits,paint,tools,scenic bits In fact everything I require, all I need is glue nothing else that's it just glue nothing but glue simple.....isn't it?....
  • Alan 45
    • Nov 2012
    • 9833
    Yup until you see that model that you need as well
      That's when the voices in your head start saying go on you know you want it who is going to know.
      • BBdave
        • Aug 2014
        • 825
        Well I am only popping in because the wife's having her hair done I'm certain all I'll get is glue that's all I need.
          • 22983
          Good luck with just getting the glue that you only need yes just the glue
          • Alan 45
            • Nov 2012
            • 9833
            Just the glue ! Just the glue! You can't handle the glue [ATTACH]87710.IPB[/ATTACH]
            • Neil
              • Nov 2013
              • 495
              • Neil
              • Consett
              If the wife is really quick in the hairdressers, no problem at all, just glue. My wife is really quick - well 2 hours or so, I mean seriously, what could possibly happen in a model shop in that time, barely enough time to browse really.
              Neil.
              • BBdave
                • Aug 2014
                • 825
                Exactly what can possibly go wrong?
                  • 18302
                  You're new at this aren't you?
                  • BBdave
                    • Aug 2014
                    • 825
                    Originally posted by \
                    You're new at this aren't you?Ian M
                    Yep!
                      LEAVE YOUR WALLET AT HOME
                      • john i am
                        • Apr 2012
                        • 4019
                        Good luck with "just" the glue but I went into my LMS the other day for just masking tape and was so shocked when I came out the shop my wallet was £85.00 lighter I'm so happy I didn't need glue as I'm sure that's a lot more expensive o_O
                        • Peej
                          • Aug 2014
                          • 919
                          When you get home and unpack the bags you will realise you have forgotten the glue!
                            Wait until you see the whole range of different types of glue available. You start off with a tube of cement, then next day you decide you need a bottle of Liquid Poly. Then to put the canopy on you want some PVA so it's another trip to the shop. Next time the cement is just a bit too thick and the Liquid Poly evaporates too quick so you want a Liquid Cement.
                            Meanwhile your glue has probably set you back about 200 quid in rare and hard to find kits you 'needed'. They are the ones that you are worried might not be made for much longer and you have always fancied one. So now you need some more paint. While you get that you realise the Liquid Cement you bought isn't quite the consistency you wanted so you might just try the Revel one instead.
                            I wonder how those weathering powders work, and that new grass looks really good, if only I had a nice tank to go with it?.................
                            You may as well admit defeat now, it's a lifelong disease!!
                            • Peej
                              • Aug 2014
                              • 919
                              Wait until you see the whole range of different types of glue available. You start off with a tube of cement, then next day you decide you need a bottle of Liquid Poly. Then to put the canopy on you want some PVA so it's another trip to the shop. Next time the cement is just a bit too thick and the Liquid Poly evaporates too quick so you want a Liquid Cement.Meanwhile your glue has probably set you back about 200 quid in rare and hard to find kits you 'needed'. They are the ones that you are worried might not be made for much longer and you have always fancied one. So now you need some more paint. While you get that you realise the Liquid Cement you bought isn't quite the consistency you wanted so you might just try the Revel one instead.
                              Is there a cure? Hope not, enjoying it too much!
