Blacken-it no longer made!
  • slupanter
    • Jun 2010
    • 554
    Hi Guys,
    I'm in a panic! I use this stuff by the lorry load. Does anyone know any alternative stuff?
    • 18286
    I guess you are talking about that bath you put brass in to make it turn black/brown.
    If so I would suggest a model rail shop. I am sure that they will help.
    On a more adventurous foot, you could try brewing some. I cant remember the ingredients but I have read/seen that its easy and the chemicals are available..
    I think I was it on You Tube...
    • rickoshea52
      • Dec 2011
      • 4079
      • Rick
      Carr's blackening fluid does the job. There's different solutions for different metals apparently.
      http://www.chronos.ltd.uk/acatalog/Engineering_Menu_Carrs_Metalblacking_Products_289. html
        By chance came across this in John's shop. assume it does the trick as required Alexander.
        • slupanter
          • Jun 2010
          • 554
          Thanks guys,
          Found this too
            Originally posted by \
            Alexander hope you do not mind me mentioning it. But you look remarkably like Field Marshal Bernard Montgomery.
            • slupanter
              • Jun 2010
              • 554
              Alexander hope you do not mind me mentioning it. But you look remarkably like Field Marshal Bernard Montgomery. Laurie
              Why thank you sir
              I was planning on changing it to Field Marshal Alexander
              Anyone just the AK or other brand blackening solution?
                As Ian suggests all the railway modeller suppliers have various blackening fluids. Try the American modeller supply companies as well, a lot do international mail order.
                • slupanter
                  • Jun 2010
                  • 554
                  Hey thanks guys
                  What do you think of this stuff
                  http://www.frost.co.uk/extra-blue-blacking-solution-for-metal-blacking-kit-1-litre.html?___store=default&gclid=CJe-ls-P6sICFRHHtAodtWUAQQ
                  • rickoshea52
                    • Dec 2011
                    • 4079
                    • Rick
                    Why thank you sir I was planning on changing it to Field Marshal Alexander
                    Like I said in a previous post, Carr's make blackening solutions for different types of metal. As well as the previously mentioned website C&L Finescale sell this stuff.
                    http://www.finescale.org.uk/index.php?route=product/category&path=440
                    • aaron
                      • Oct 2011
                      • 2019
                      Yep AK interactive do a soluion for metal tracks.
                      • tanktrack
                        • Jun 2012
                        • 1429
                        im using ti hobbies track blackener and it is good look at tihobbies.co.uk for it
                        • slupanter
                          • Jun 2010
                          • 554
                          Like I said in a previous post, Carr's make blackening solutions for different types of metal. As well as the previously mentioned website C&L Finescale sell this stuff.http://www.finescale.org.uk/index.php?route=product/category&path=440
                          Expensive stuff
                          • slupanter
                            • Jun 2010
                            • 554
                            Do you water yours down with distilled water?
