Tonight I ventured fourth in the the man cave to do some work on the dio I am working on. Having purchased a couple of different sorts of waer effects I thought I would try out the E-Z water method. Read the instructons set up and read the instructions again. thought this would be a pretty painless operation Heat granules till melted pour liquid where required How hard can it be? On the instructions it says if the liquid gets to hot it can spatter so I try to take every precaution I can stirring throughout etc ec etc.
Liquid gains heat a lot faster than anticipated and sure enough starts to spatter all over the cooker the floor and ME.
Now I said I thought I had all the bases covered well that isn't strictly true as one area that wasn't was the hand holding the bloody pliers that were connected to the tin I was using to heat the not so E-Z water.
Net result a rather big mess to clean UP in the kitchen and a trip to the local A&E.
To say I felt a right plonker walking in and explaining I was playing with heated resin and it got a way from me would be an understatement. Although the nurse did say it made a change to the normal Friday night traffic (by that I could only assume she meant the drunks). End result of the evenings antics a small burn to ones hand. Guess he next time I use the stuff I will be covering up.
   ops:
ops:
