Lesson Learnt
  • spanner570
    • 15599
    #16
    Originally posted by \
    Ron I take it the varnish doesn't affect the plastic at all? I don't want to be pouring anything in that willmelt the figures etc.
    No, it's fine. The only drawback is the fact that it can't be put on too thickly - 4 coats is enough to get the right watery look. Pouring is a no,no. To get the perceived depth, you need to paint the river bed various colours before the varnish is added. But the river bed / base is virtually on the surface to start with....
    I hope you understand that nonsense, as it's hard to explain with the written word. Have a blimp at the construction of the mill dio. I explain the method more clearly there.
    I think with your build being so far advanced, using varnish might not be suitable.....Scott's method produces great results and is safe.
      Cheers Ron
      • Gern
        • 9307
        #18
        That doesn't sound good Terry, I hope it heals up quickly for you.
        Deluxe Materials make a product called Scenic Water which is much safer. The instructions say you only need to stand it in a bowl of hot water until it melts, however:
        You'll need to stand it in a dish of water, then put the dish in a saucepan of water (as if you're going to steam it) and let the water in the saucepan boil for about 15 minutes!
        OK, it's boiling water - but that's nowhere near as hot as liquid resin and you don't need any special PPE.
        Unless of course you're the kind of guy that uses PPE when using a kettle to make a cup of tea!
          I do hope that the hand is ok and not too damaged, did not mean to sound insensitive earlier, but iam the worlds worst for spilling things on myself that why I use the cold pre mixed stuff.
          scott
            Sorry to hear about the mishap Terry, hope it heals up quickly!
