Hi I went to use my airbrush today when I depressed the trigger no air came out stripped it down couldn't see anything put back together still nothing took the air valve off depressed the tip air came out put back together nothing stripped out the brass rod spring and seal and reinstalled still nothing put the air valve and trigger from my other h&s in still nothing this airbrush works fine so it's not a compressor air supply problem anybody had the same issues and how did you resolve it
Regards
Regards
