I'm using some 3mm Acyrlic to make the hull of an R/C tank, I'm using Ambroid - Pro Weld Plastic Welder to join the edges.
Whats the best way of building up a bead of adhesive along the inner seams to add some extra strength? If I was using styrene I'd use some poly cement - whats the equivalent that could be used for Acrylic?
