spraying klear over ts-13 clear
  • meggsy
    • Jun 2011
    • 421
    hi
    happy new year ive just finished re-painting and re-applying the decals for my lcr honda i gave it a couple of coats of tamiya ts-13 clear before applying the decals now im wondering after the last attempt where i sprayed the ts-13 and it melted the decals im thinking of giving it a coat of klear instead is this a good idea or should i just stick to giving it several mist coats of the ts-13 incase the klear and ts-13 dont get on and im back too square 1.
    Klear over the lacquer based tamiya will be fine, the other way round would likely have the Klear reacting, (Klear is essentially an Acrylic)
    • meggsy
      • Jun 2011
      • 421
      nice one cheers
        Steve ,I've done this a lot with no ill effect. I agree with Mike the other way around would be a risky venture. Good luck and let us know how it turns out,Trey
        • meggsy
          • Jun 2011
          • 421
          hi
          thanks for the advice i played it safe and stuck with the ts-13 seems to be ok this time i will try that method on my next build just didnt want anymore probs this build has been a bit of a mare be glad to finish it
          regards
