engine wont keep goin
    Originally posted by GerryW
    Until they come up with an electric vehicle that will do 350 miles minimum during winter (lights and heater going) without charging (sister lives 340 miles away) or a hybrid that will do 50+mpg (why don't they do a diesel hybrid??) plus able to tow a 1+ tonne trailer, I'm going to be stuck with an ice vehicle.
    Have you seen this Gerry.
    • simontie
      • Jan 2010
      • 1515
      #47
      Originally posted by boatman
      HI 570 NO PROBS but is it on utube as this story takes some beleiveing i think this is one of your wind up post ? lol
      chris
      Seen this movie a few years back your right its a great film, thought i was the only one who seen it lol
      Why is common sense not so common?
      • simontie
        • Jan 2010
        • 1515
        #48
        Hope you got the mower going? we have a few small engines at work and not many people know this but some manufactures have an oil level cut out in there 4 stroke engines so if they run low they won’t run they start and cut out couple of seconds later. Its designed to stop you ruining aperfectly good engine but a real pain if you dont know about it, you have no idea how many people i have complaining about that genny won’t run, check the oil and always low or they have it on a slope…
        simon
        • Airborne01
          • Mar 2021
          • 4300
          • Steve
          • Essex
          #49
          How old is the fuel in the mower Chris? Unleaded fuel is only good for about six months. After that the ethanol in the fuel absorbs too much moisture from the air to work properly.
          What is termed 'the light ends' may evaporate off and the two mentioned causes result in a 'gunk' forming that blocks jets and even fuel lines - much like beer lines that aren't pulled through often enough :disappointed2:! As mentioned, drain fuel tank; using kero clean filters and lines and flush through with a little fresh fuel. Oh, and check for rust particles or discolouration - this has often worked for me in the past mate!
            Can you use Fire ! :nerd:?
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #51
              OH John you had to ask that dint you could not resitit could you boy oh boy
              chris
                • 18302
                Not sure that’s a particularly good idea Ian. Apart from the obvious safety concerns, ethanol is one of the additives used to reduce pinking in an engine so minimises damage. In addition, modern car injector control systems are designed to work with ethanol mix petrol. E10 produces about ten percent less CO2 per unit volume burned than ethanol free petrol. Removing the ethanol will cause the engine management system to work inefficiently when trying to control emissions, in turn reducing engine power and decreasing engine life.
                Seems like the petrol head equivalent of the anti vax movement to me!
                I WAs thinking more for use in small engined garden machines most of which are two stroke.
                  • 19106
                  Ah, right. I think modern two stroke oil contains fuel stabilisers anyway. I certainly haven’t had any issues with mixed two stroke going off. Then again, I only mix half a litre at a time for my strimmer/multi tool. The mower has ia four stroke engine.
                  • GerryW
                    • Feb 2021
                    • 1757
                    #54
                    Will have a proper look at it tomorrow, thanks
                    • Airborne01
                      • Mar 2021
                      • 4300
                      • Steve
                      • Essex
                      #55
                      That looks a fine chassis!
                      • Airborne01
                        • Mar 2021
                        • 4300
                        • Steve
                        • Essex
                        #56
                        Saves wasting money on lawn mowers :tears-of-joy: !
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #57
                          YES i love chassis! lol
                          chris
