Spots on the Internet (2022)
    If I was in the market for a 'ghost ' I'd go for this
Name:	icm decals.jpg
      are these the tracks for the full models released as separate boxings, or different tracks?
      They look to be the same tracks as in the kits: again, look at the renderings I posted a few pages ago, they show the same construction as in this boxart.
        • 18302
        Talking Of Decals...
        Just saw a video on YouTube Eduards New decals.
        The carrier film is on the top and once the decals are dry, you peel the film off leaving a "painted on look".
        Could not find any info on Eduards webshop but a Google of "Eduards new decals" does the trick.
        They look rather good when done!
          • 19130
          Interesting development Ian. It may be the way forward. Not that new a concept, but looks like the best iteration of it so far. Little big man shield transfers are very similar but need underpainting in white. Methfix railway transfers also worked the same way, but were released by meths rather than water and you had to wait for one to dry before you could add another, so were quite slow to use.
          • The Smythe Meister
            • Jan 2019
            • 6248
            #755
            I like the thought of the "Painted on" look
            • stillp
              • 8308
              • Pete
              • Rugby
              #756
              I was rather surprised that the DecoSol was used before removing the carrier film. Good result though.
              • adt70hk
                • Sep 2019
                • 10551
                #757
                Interesting and look very good.
                Thanks for sharing Ian.
                  On the Takom Face book page - in addition to the M48 Family models - further October releases
Name:	takom october.jpg
                  On the Special Hobby Facebook page - a reissue with new parts...............
Name:	sh piaggio 01.jpg
ID:	1184024Click image for larger version
Name:	sh piaggio 02.jpg
ID:	1184025Click image for larger version
Name:	sh piaggio 03.jpg
                  Now, that camo paintjob must have been a labour of love!
                  • adt70hk
                    • Sep 2019
                    • 10551
                    #759
                    [ATTACH=CONFIG]n1184024[/ATTACH][ATTACH=CONFIG]n1184025[/ATTACH][ATTACH=CONFIG]n1184026[/ATTACH]
                    Can't even begin to comprehend how long that took..... And at 1/72 too...... That said I can't imagine the factory employees or ground crew or whoever painted it on being to pleased either!
                      On the Kinetic Models Facebook page
Name:	kinetic raaf hornet.jpg
                      On the Special Hobby Facebook page - The Meteor World Speed Record Holder
Name:	sh meteor 01.jpg
ID:	1184098Click image for larger version
Name:	sh meteor 02.jpg
ID:	1184099Click image for larger version
Name:	sh meteor 03.jpg
                      On tha AZ Model Facebook page
Name:	az salamander.jpg
                      A paper project model ( A-9 - swept forward wings, butterfly tail? ) in combat with P-59 Airacomets
                      • Steve Brodie
                        • Sep 2014
                        • 4652
                        #761
                        Unless i am missing something, dont see the point. still need a gloss surface, use of Sol & set, which you do with normal decals. Peeling the carrier away runs the risk of scratching the painted surface and lifting the decal away - 5:03 on video.
                          • 19130
                          Peeling the carrier away seems awkward to me as well, and is certainly not for everyone. However, the bonus is that you have no carrier film “step“ in the finish afterwards and the risk of silvering must be materially reduced as it’s usually the clear carrier film that causes that problem. Like most things, it seems worth a try.
                            • 18302
                            Can you imagine the uproar when someone builds one of these fantasy things and I move it to the fantasy section.... lol
                              • 18302
                              That would be what the tankies call chipping Steve. :tongue-out3::tongue-out3::tongue-out3:
                              I did wonder if masking tape could lift the film as well...
                                • 19130
                                Used to be a very old technique with letraset if I recall correctly. Basically, if you wanted white lettering, spray the model white, put on letraset numbers over the white, paint the item the colour required, then lift the letraset using sellotape…….
                                Never tried it, and never will now
