Having a bit of a problem
    Sorry to read of your woes Dave . Hope all is sorted soon .
    • Andy the Sheep
      • Apr 2019
      • 1864
      • Andrea
      • North Eastern Italy
      #47
      My best wishes for a conclusive and positive result from your analysis, Dave.
      • Mark1
        • Apr 2021
        • 4156
        #48
        Hope you can get back to the bench soon dave, all the best.
          An update - after various tests, the Doc tells me that I'm suffering from a Kidney problem - he was puzzled, because there's no other signs of it, but a specific test ( more blood....) seems to have pinpointed it. I'm being taken off one medication entirely & my dosage of another reduced, for a month. He says that should help in the renal side & I should have a bit more energy - fingers crossed!
          No benchtime yet - but, even if I was feeling OK, I doubt that I could have done anything - my thermometer has hit 37C, the hottest I've seen here! Most unpleasant going to the Doctors, it was like standing in front of a hair dryer - not comfortable - it's supposed to break over the next few days - Wednesday at least 10C cooler.
          • Mark1
            • Apr 2021
            • 4156
            #50
            37 here too,hotter tomorrow :tired: at least your getting to the bottom of it now, with a bit of luck you'll be back to gluing bits of plastic to your fingers soon:smiling3:
              • 16157
              At least the docs have found the problem. Hopefully there will be improvements soon.
              We aren't quite 37 here but very close. Our main problem is the heat is setting off the smoke alarm in the hall. It's wired into the mains so I switched off at the fuse box but forgot it has a back up battery so the b****y thing is still going off every half hour or so :worried:
                • 19103
                Better hope it goes flat by the evening Jim. Wouldn’t want to keep everyone awake….failing that, put some tape over the sounder holes. It’s surprisingly effective.
                  • 19103
                  Hope that sorts it out Dave.
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #54
                    DITTO Dave from jen an me
                    chrisb mtb an jen
                      That's one good bit of news then Dave, hopefully it will make an improvement.
                        THANKS ALL!
                        I have to admit it was getting me down a bit! As an extra, the Doc looked at my diabetic control & he said keep on doing what you are doing now, don't change anything. He noted I was diagnosed diabetic just on 21 years ago ( to the month ), and some of my parameters hadn't changed over the past ten years - I'd even lost a bit of weight. !!
                        • scottie3158
                          • 14565
                          • Holbeach
                          #57
                          Dave keep not taking the tablets :smiling: glad to hear they are getting to the bottom of it.
                          • adt70hk
                            • Sep 2019
                            • 10540
                            #58
                            Dave, as the others have said pleased to hear they have a identified the problem. Hope it doesn't take too long to get it sorted.
                            ATB.
                            • The Smythe Meister
                              • Jan 2019
                              • 6248
                              #59
                              ATB.
                              Yep,.
                              Good news indeed Dave...
                              Although there's obviously "The wait" yet ... But I'm sure it'll be ok
                              Have you been on Statins?.. they're often prescribed to people with Diabetes, blood pressure,sugar level type problems....
                              And a side effect of them can be Liver/ Kidney problems as I was told by my GP a few years back! ....
                              ... I declined the offer!!
                              Looking forward to seeing you back modelling again mate
                              Take care... This baking heat can't last forever!!
                              Andy
                                Yep,.
                                Although there's obviously "The wait" yet ... But I'm sure it'll be ok :smiling3:
                                Looking forward to seeing you back modelling again mate :smiling3:
                                Andy
                                I've been on Simvastatin for a long time, and it has kept my cholesterol at the correct level, the med I'm going to stop is Ramipril, a BP control & I'm halving my dose of Metformin, a diabetic med. The doc advised me to take my BP regularly over the next month, but he didn't think that'd be a problem. I have my own BP machine, so that's easy.
                                It's 03:30 & the temperature is now a comfortable 24C, but it's forecast to be even hotter today, so, it'll be drawn curtains for half the day........
