Shop ?
    Shop ?
    Tried to log in to the shop , no luck. Asked for new pass word, said it would be sent and to allow time. Nothing, also did the contact and sent John a message.
    Anyone else had trouble logging into the shop, my password has never changed recently and certainly not my email address .
    • 16294
    Yes John. I was able to easily reset my password.
    • Gary MacKenzie
      SMF Supporter
      • 1059
      • Gary
      • Forres , Moray , Scotland
      The shop email system sent an email on Thu, 17 Feb, 11:05 , stating that we would need to re-register to use the shop system ( all orders already in system would be fine ) and gave a discount code as an apology. ( code is now outdated )
      • John
        • Mar 2004
        • 4700
        • John
        • Halifax
        For some reason earlier today the emails are getting queued on the server, you should get it soon.
        you can login with your email as both user/pass once your logged in you can change it
        www.scalemodelshop.co.uk
          Thanks John .
          • Jack L
            • Jul 2018
            • 1285
            • Cheltenham
            I'm having to reset my password every time I want to log into the shop.
            • John
              • Mar 2004
              • 4700
              • John
              • Halifax
              You shouldn’t do, are you using a password manager? And is that storing the old password, I login several times a day and have never had to reset my password
                Cheers Gary
                Good to read that Jim.
                  Well just looked at my emails and nothing from the shop for changing my pass word ?
                  • John
                    • Mar 2004
                    • 4700
                    • John
                    • Halifax
                    It’s in a queue to be sent, did you try logging in using your email as your password?
                      Morning John .no
                      Would that help ?
                      • John
                        • Mar 2004
                        • 4700
                        • John
                        • Halifax
                        Would that help ?
                        Yes that is why I said “you can login with your email as both user/pass once your logged in you can change it” in my first post
                        Ive contracted the support for the Mail sender I use, it’s common for emails to be queued or deferred for people with Yahoo or AOL email addresses.
                          All good thanks John.
                          • adt70hk
                            • Sep 2019
                            • 10551
                            Thanks John, double email worked for me.
                            • Jack L
                              • Jul 2018
                              • 1285
                              • Cheltenham
                              Both. Autofill should be up to date, but have entered in manually as well. I'll reset it again, and let you know if the issue occurs again.
