Project modelling room!
  • colin m
    • 9063
    • Colin
    • Stafford, UK
    #61
    Bob, I realise I'm late to the party, but have you considered an insulated garage door. Admittedly, they do cost a bit, but really work well.
    • BattleshipBob
      • 6881
      • Bob
      • Cardiff
      #62
      Hi Colin
      The room is located about a third of the way into the garage. With plywood walls on both sides and the end walls of the room where they meet the garage walls, with insulation in between. Should be warm enough to both work on and protect the paints. Going to buy 2 cheap thermometers to put in the room and in the actual garage so I can compare the temp.
      Do not know if painting the floor will help as well??
        • 18302
        Looking good Bob. One thing though. You might regret those paints and spray cans right by the window.
        I have an L shaped bench and got very quickly tired of the leg in the angle. It is now removed.
        • BattleshipBob
          • 6881
          • Bob
          • Cardiff
          #64
          Good point, no doubt as I start to.use the room problems like that will shoe, thanks Ian
          • BattleshipBob
            • 6881
            • Bob
            • Cardiff
            #65
            Electrician calling the week to have a look yippee
            • minitnkr
              • 7804
              • Dayton, OH USA
              #66
              Sealing the floor will definitely help. You can just glue sections of solid insulation on the door sections, remember to bevel edges for the bend at roll-up.
                Oh you will be so happy in there Bob, you close the door to the horrible outside world we are in at the moment.A sanctuary indeed . Half of the fun is finding where you want to put things .
                The only thing I can suggest is think about that floor ! Cold concrete in the winter is not nice .
                • BattleshipBob
                  • 6881
                  • Bob
                  • Cardiff
                  #68
                  Nearly finished!!
                  Electrics done, spent this morning fitting a rug I found on the garage rafters, brand new still packaged. No idea when we got it???
                  Where there was exposed garage floor I put down some Mexican carpet, underlay, underlay!!!! Here all week lol.
                  New large booth on the way,
                  Joint birthday pressie!!
ID:	1185436Click image for larger version
                  Will now keep an eye on temp differences between garage and room
                  Pleased so far
                    • 19130
                    Looking good Bob…..you are going to love it…
                    Where did the spray booth come from, by the way?
                    • adt70hk
                      • Sep 2019
                      • 10551
                      #70
                      soooooo jealous Bob!!!
                      • BattleshipBob
                        • 6881
                        • Bob
                        • Cardiff
                        #71
                        Thanks Tim, from bartsharpairbrush
                        Just hope it's warm enough lol
                          • 16293
                          Looks ideal Bob. A real bolt hole from the stresses of life. I like that spay booth.
                          • BattleshipBob
                            • 6881
                            • Bob
                            • Cardiff
                            #73
                            Thanks Jim, hope you are well
                            The one coming is the same, can then get a long 1 350 ship in them when they are joined together
                              Looks good Bob, your going to have hrs of fun in there .
                              • Ancientmariner
                                • Feb 2018
                                • 867
                                #75
                                Fantastic, a lovely modelling space you have there!
