Stupid laws. Rant warning.
    • 18302
    Just had the 4x4 MoT tested.
    Fail! What!?
    On the inboard face of the front discs is a thin stripe rust at the inner edge of the contact area. Instant fail Due to EU rules that are enforced upon us in DK. This is the second or third time this has happened. So now I need some new discs! which means new pads and mounting kit!
    The best bit? The breaks function was 100%. both stopping power and equal both sides. But nope not good enough. so I also have the pleaseure of a re-test to pay as well.
    Bugger!
    Apparently my rear fog lamp needs changing as well. lol. Wonder how you turn those on an off. (yes I use them that much ).
  • AlanG
    • 6296
    Can you not get the discs ground to remove the rust?
    • Mark1
      • Apr 2021
      • 4156
      If its not pitted you could try sanding it off.i shaved off the rear door handles of a car once ,mot said they have to be opened from outside the car so i took it for mot with the back windows open,it passed! Cant remember last time i had a car fail, there is some perks to being in the motor trade
        • 18302
        Not a thing in Denmark. If I had a lathe...
        There is a scratch that runs around the disc 1/3 of the way up. So I dont think that would work. Funny thing is the outside face of the disc is perfect! you know the bit you look at once in a while (and before you go to the MoT hall!)
        A Ha! the fog light bulb is fine. I swapped it around with the reversing light. still no for light.
        Checked the fuse. fuse fine. just asked what a switch would cost.... £50! another place said £80. lol.
        me thinks I will just check the tails for the lamp holder....
        • eddiesolo
          • Jul 2013
          • 11193
          That is a crapper Ian, very stringent MOT. I can understand the need for MOT's but when the brakes are still 100% efficient then surely a 6 month inspection thereafter would suffice and replace if needed, I take it is is on all four wheels?
          • BattleshipBob
            • 6881
            • Bob
            • Cardiff
            There are brake disc grinders / skimmers, use to have one in a Nissan dealer I worked for. Nissan would only pay for discs under warranty if they could not be skimmed.
            • KarlW
              • Jul 2020
              • 1522
              I think there's some things that they pass/fail depending on whether they got lucky last night, fail on coroded break pipes, pass after a wipe with an oily rag.........
              • Mark1
                • Apr 2021
                • 4156
                Probably just a corroded conection on the light, easy check with a circuit tester.
                • stillp
                  • 8308
                  • Pete
                  • Rugby
                  We don't know how deep the scratch and the rust are though, they'll work fine up until the moment when they don't!
                  My TR4A failed (when I was living in Cardiff) on "Brake unbalance", which when I questioned it was told there was a mark on the discs where the pads had been sitting for several years. I used a flap wheel on an angle grinder, while spinning the disc, to polish out the mark, and it passed. I never went back to that test station though!
                    • 18302
                    Nope. All connections are squeaky clean and tight! circuit tester shows a good circuit: in the bulb, so that's good. the wire from the bulb holder to the con block also a good circuit.
                    If I could find out how to get the bl**dy switch out I would test that as well. But getting it out is proving to be the hard part.
                    • rickoshea52
                      • Dec 2011
                      • 4081
                      • Rick
                      Fail! What!?
                      Bugger!
                      I’ll be in CPH October to remove corrosion from a landing gear, can you wait that long!!?
                      • stillp
                        • 8308
                        • Pete
                        • Rugby
                        Is the earth connection good?
                        • The Smythe Meister
                          • Jan 2019
                          • 6248
                          Straight bananas and irregular potatoes banned.....
                          ... Just so glad I voted "Out"...
                            • 18302
                            There is an earth wire clean and tight no corrosion...
                            • Graeme C.
                              • 1628
                              • Graeme
                              • UK
                              Usually a bad earth causes the problem, a circuit tester will find it.
                              A friend once had his Land Rover failed for 'handbrake cables to rear brake drums not present'. It had disc brakes & a transmission handbrake. Tester was not amused when he parked it on a slope with the engine running & got out. Probably even less so when he showed him the handbrake drum on the back of the gear/transfer box.
