What colour to paint my garage floor for modelling?
    Hi,
    I have now bought a house with a garage so I can finally get on with my model bismarck after far too long leaving it on the shelf.
    Now I am going to be painting the walls white to help with light etc but I am wondering what to colour to paint the floor? I was thinking white but there doesn't seem to be a white concrete floor paint that I can find. So was thinking light grey but not sure if parts that ping off will show up very well?
    What do you guys think?
    Thanks.
  • AlanG
    • 6296
    Paint is whatever colour you want and then get an off cut of light coloured vinyl flooring and place that around your workstation. Alot easier
    • BarryW
      • Jul 2011
      • 6139
      In your position I would paint the area around the workstation a hard wearing brick red. There are not many parts that won't show up against that colour. I have floorboards (with gaps!!!) and they are the bain of my life...
        Actually I might just use vinyl to cover the whole of the floor as they do that in white and it's not too expensive
          • 18302
          Given that very few kits are in black plastic, I would paint the floor black but vinyl would be good at you can hear where things land better.
          • yak face
            • Jun 2009
            • 14308
            • Tony
            I'm with ian , black floor then a piece of vinyl flooring under where you sit. Not only will this make bits easier to see but if you cant find them ,a sweep of the vinyl into a dustpan, then empty the contents onto an a3 piece of paper usually finds it. The vinyl being a lot easier to sweep carefully into a pan ,not having any little nooks and crannies the errant bits can get into like a rough concrete floor would. cheers tony
              AFK I went down to B & Q & they do cheap carpet tiles. Has a very short pile.
              Advantages. Little plastic parts do not ping off it so easily in all directions. Plastic backing stops damp. In the winter it is a bit more comfortable & warmer. If you mess up a tile just replace it.
              If you use the garage for your car, heaven forbid, it soaks up the oil very nicely.
              Finally a really super advantage. Lay in a light grey & dark grey checker board & you can play draughts or chess while waiting for the paint to dry.
              On a serious note I would question white paint. Very harsh light with flash back. I would have gone for a very light fawn. Also all in matt emulsion.
              Add. The carpet takes away the hollow/echo sound you get in a garage.
                Paint it Tartan...
                  Very funny. Only a nutty Scotsman could have thought that up.
                  I burst out laughing when I saw the tin.
                  My only complaint, being a member of the clan Stewart, is that the "shade" should be Stewart of Appin which would be more appropriate.
                  Do they do alternatives Andrew ?
                  • AlanG
                    • 6296
                    Prefer Clan Sinclair Hunting tartan myself
                      Being an ex decorator I`ve used this stuff before but you need a left handed brush to get the best results.
                      I will get my coat
                      Richy
