Led Lamp
  • Crispier
    • May 2023
    • 43
    Led Lamp
    Can anyone reccomend an LED lamp? I've seen tons online at quite different prices for the same lux values, I dont want to go cheapo and regret it nor do I want to remortgage my home, reccomendations from modellers is the best route IMO.
    TIA
  • Tworrs
    • Jan 2022
    • 1982
    • Garry
    • New Zealand
    TIA
    The only advice I will offer is to try for a daylight lamp, something around 5500 Kelvin, that way you will have a better reflection of true colours.
    • Crispier
      • May 2023
      • 43
      Thanks, narrows down the search :thumb2:
        • 19130
        I’ve got something like this….
        I say something like it because I’ve had mine a good few years and the exact model is no longer available. Should be good enough for general modelling.
        • Crispier
          • May 2023
          • 43
          I've just purchased the one in the shop
          [HEADING=2]Compact Led Task Lamp With Dimmer Lightcraft LC8005LED[/HEADING]
          Shop Compact Led Task Lamp With Dimmer Lightcraft LC8005LED including paints, weathering effects, tools, and accessories for scale modelling. High-quality products trusted by hobbyists worldwide. Fast UK delivery.
            • 16293
            Good choice. Good lighting and some magnification (especially for us older modellers) can make a huge difference.
            • Andy T
              • Apr 2021
              • 3239
              If you want a backup lamp, for extra light from the side or whatever, I can recommend the Tertial anglepoise lamp from Ikea. Fitted with a good daylight led bulb you have a cracking light for under 20 quid.
              It won't have the spread of the one above but I find them great when you need a bit more light from a different angle.
