I'm about to paint some brass sidetanks on my loco the tanks have a lot of raised rivet detail, also the finish will be satin rather than gloss so how to get a good smooth finish? Rubbing down between coats will remove paint from rivet heads and as it's a satin, can't really polish once it's done.
					Advice wanted - painting G Scale/ 16mm Loco
	 GuestTags: None GuestTags: None
	 Guest Guest
 Hi Alan have you tryed using a non petroleum based rubbing compound such as Mr Hobby SF fine compound or 12000 grit sand cloth or try using some soft white stryrofome. GlennOriginally posted by \I'm about to paint some brass sidetanks on my loco the tanks have a lot of raised rivet detail, also the finish will be satin rather than gloss so how to get a good smooth finish? Rubbing down between coats will remove paint from rivet heads and as it's a satin, can't really polish once it's done.
