Help with ariels
    Help with ariels
    Hi folks hope someone can assist me with a slight problem, i build 1:35 scale armour and so far have been unsuccessful in finding somthing i can use as radio antennae for WW11 armour. I have tried melting spruce but i'am a little cack handed with this technique, although i keep trying can someone offer a good realistic alternative, thanks.
    Scott
  • yak face
    • Jun 2009
    • 14237
    • Tony
    hi scott,do you know anyone who plays guitar? The old strings are brilliant for all sorts of uses,the thinnest single wire ones would be perfect for an aerial,strong enough and flexible too.The thicker wound strings are good for allsorts too,oxygen pipes in planes,flexible hoses on engines ,the skies the limit.Hope this is of some use cheers ,tony
      hiya Scott, i tend to use these
      Military Models and 1/35 Scale Models by Accurate Armour
        That looks good stuff Langy, might just invest in a few.
        ian.
        • spanner570
          • 15599
          I build 1/35 armour too and I had the same problem, but no more.
          The solution is to buy a card of good old fashioned fuse wire.
          On this you will find 3 sizes, use the 15amp size, this is the perfect size for 1/35. A dab of super glue and away you go. I have photos in the gallery and you might just spot the antennas!!!
          I hope this is useful to you.
          Ron
            Thanks
            Originally posted by \
            I build 1/35 armour too and I had the same problem, but no more.The solution is to buy a card of good old fashioned fuse wire.
            Ron
            Cheers for that bit of knowledge spanner i have a load of that in my tool box it just never occured to me to use it.
            thanks
            scott
              good call
              hiya Scott, i tend to use theseMilitary Models and 1/35 Scale Models by Accurate Armour
              Thanks for thant just checked out the link you sent me i will have to get some of these .
              Scott
                Hi folks hope someone can assist me with a slight problem, i build 1:35 scale armour and so far have been unsuccessful in finding somthing i can use as radio antennae for WW11 armour. I have tried melting spruce but i'am a little cack handed with this technique, although i keep trying can someone offer a good realistic alternative, thanks.Scott
                Hi Scott
                Check out www.accurate-armour.com, you will find them there, bought some last week
                Good luck
                Taff
