Puma road dust
  • slupanter
    • Jun 2010
    • 554
    Puma road dust
    Im justing MIG pigment. If my puma is in normandy Dry do i wash the the lower hull with "light dust" ?
  • slupanter
    • Jun 2010
    • 554
    Sorry I mean "Im using MIG pigments. If my puma is in normandy and Dry do i wash the the lower hull with "light dust" ?
    • yak face
      • Jun 2009
      • 14308
      • Tony
      hi alexander, light dust sounds ok to me but are you planning to make a wash with the pigments or just dust them on dry, i would do the dry method myself . cheers tony
        Or even a bit of both, do a wash first which will pick out the edges and 'shadow' areas. then do a gentle dry dust to even it out and leave it light dusty in the centre of the panels.
        The great thing with Mig Pigments is that if you try it using dry or wet with water, if it goes wrong, just wash it off with a wet brush soaked in water. I am new to pigments myself and marvel at what can be done with it. Like everything else in modelling, it is trial and error experimentation and going with your gut feeling sometimes.
        • slupanter
          • Jun 2010
          • 554
          Will it work if i put it on dry then matt varnish it. Will it stay?
          • slupanter
            • Jun 2010
            • 554
            I think I'll use graham idea aswell.
            • yak face
              • Jun 2009
              • 14308
              • Tony
              If you varnish it alexander it would probably wash it off and darken it too,so i would just leave it dry and dusty ,cheers tony
              • slupanter
                • Jun 2010
                • 554
                Tony, Should I dust the whole puma?
                • yak face
                  • Jun 2009
                  • 14308
                  • Tony
                  Hi alexander i would mainly use the pigment round the bottom half and the wheels , cheers tony
                    Dust whatever parts you want dusty. Look at real life things be it cars, vans whatever. you will see that dust on vehicles varies so there is no set answer, just dust it until you are happy with the results.
