Latest acquisitions
    Had this dropped off this morning by the postie
      Originally posted by \
      Can it cut polystyrene sheet? Up to what thickness? I think it could, up to 1 mm thickness but thicker might be a problem, poly being quite hard. By the way, when cutting thick poly sheet, I use my Tamiya scriber. It cuts a groove in thicker sheet against a ruler (well held or clamped) which can be deepened with successive passes
      I would think it can cut poly sheet. It is a scalpel blade and if you use a ruler and a scalpel, cutting poly sheet is possible. All it would mean is taking a few passes at it.
      The main purpose of the tool is that it is a guide so gentle passes on harder materials would be the order of the day. This is not a jackhammer, by gentle cuts with minimum pressure you will easily get consistent and accurate cuts.
      It is designed to cut cork and other materials of a similar nature, like balsa or foam sheets which it will do easily and without effort. If you use it for thicker harder materials, it may not last as long. Like any tool, it should be used safely within its design parameters.
        [ATTACH]154898[/ATTACH]
        Tasty bit of heavy metal Tom
        • Gern
          • 9301
          #4984
          Had to show this one!
          No, it's not for washing off mould release! It's gonna save me a couple of hours a week up to my elbows in soap suds at the kitchen sink - so I'll have that much more time slaving over bits of plastic at the workbench! Yeah!
            Thanks Graham
              Hi all, still yer me. Just been busy and on my hols. Picked the up the two Dragon kits in Tavistock's Pannier Market. I think I got a good deal. They were displayed as 20% off so I asked if I would get further discount if I bought both. Ended up at £70 for both.
              • Bigfoot57
                • Jun 2015
                • 1141
                #4987
                Just got this from one of our section managers who has given up even starting this apparantly been in his loft for 5 years
                Regards
                Colin
                • peterairfix
                  • Jul 2012
                  • 11139
                  #4988
                  Just came back from the recycling centre with these six I got them for £15
                  • monica
                    • Oct 2013
                    • 15169
                    #4989
                    nice haul Stuart,do like the Thunderbirds one,
                    • john i am
                      • Apr 2012
                      • 4019
                      #4990
                      Hi folks up with the birds this morning at the car boot n came away with this little haul.
                        Wow John!
                        I love the ECTO one  :x
                          How many kits John!?
                          More Airfix Mustangs I see
                          • PaulTRose
                            • Jun 2013
                            • 7096
                            • Tattooine
                            #4993
                            nice haul!!
                            ive done the Star Wars Trade Fed Tank......nice kit but quite a size, love to do another some day
                            Per Ardua
                            • monica
                              • Oct 2013
                              • 15169
                              #4994
                              wow John some great kit you got,do like your haul very much,
                              • Adrian "Marvel" Reynolds
                                • Apr 2012
                                • 3008
                                #4995
                                Told you when I saw you earlier you had a good selection mate, everytime I go to that car boot its just tat with not a kit in site
