needing help
    needing help
    Hi folks I'm needing some assistance with scale. I have been working on a 1/32 A10 problem is there's not much in the way of ground crew, someone here put me on to figures that would have been perfect but they are sold out, so i have ordered a few 1/35 figures that might do but am concerned with the scale issue. Can they be used without the dio looking out of place?
    Scott
    A figure is going to come out at 6 or 7 inches shorter in 1:35 scale, OK if you're modelling jockeys :smile1:
      • 18302
      An average height of five foot six in 1/35 is around 1,88 inches in 1/32 scale he is going to be around 2 Considering that real people come in all shapes and sizes, as do figures (tamiya, Mini art, Bronco figures in 1/35 are all different heights and stature). If you can find the figures you need from the one maker you should be OK or so I would think.
        • 18302
        What are the figures you are after?
        • stona
          • Jul 2008
          • 9889
          Oddly enough I was in this same quandary myself recently.
          According to my "back of a beer mat" calculations a person my height (1.72 metres) would be 4.6mm shorter in 1/35 compare to 1/32. His real height would apparently be reduced to 1.57.
          The difference in scale height is less than 1/4 inch in old money and I decided to go with it only to find what I wanted in the correct scale.
          I'm looking at two 1/32 scale figures now,standing beside a 1/32 aircraft and I'm quite sure that if they were 1/35 scale instead nobody would be able to tell.
          Mixing figures in the two scales might make the difference more visible.
            Originally posted by \
            What are the figures you are after?Ian M
            A few modern ground crew for my A10 dio is all i received the M274 mule in 1/35, was planning on using that and out re do the marines with it to look like loaders.
            Scott
              • 18302
              Products from Figures 1 32 - Figures-soldiers-pilots-personnel - Hat Figures 1 32 - Zouaves - Hat
              They say they have them in stock....
                Hi Scott
                Academy do 2 sets of modern aircraft crew figures in 1:32 scale, I have posted the link for you, hope this helps mate. http://www.wheelspinmodels.co.uk
                Tom
                  Ian thanks for the heads up these are the figures i've been trying to get my hands on, ordered them this morning..... cheers for the heads up and thanks to everyone for their advice.
                  scott
                    • 18302
                    Your Welcome Scott.
