Tiny little Nuts, bolts, washers and Screws...
    • 18286
    No not the joke.
    I have a serious need for a couple of hundred sets of the above. Calibre 35 (Do they exist still) do/did just the job but are rather hard to find. Hannants sell them but the size I want are sold out. I need the 1,5mm size sets.
    Any one got any ideas as to who else sells them. Searching the net has not turned any thing up. The places I have found are all sold out and Calibre 35 have yet to reply to my emails.
    Failing that does any one know where you can buy real ones is´n such small sizes, or how I can make them?
    At the moment I thing I will need about 150 of them!!!
    How about this: HobbyEasy | Bolts & Nuts 1,5mm - 360pcs
      Found these if they're any good
      HobbyEasy | AFV
      120 HKD works out about a tenner, not sure what their delivery is like
      Czech Master Hexagonal Bolt Head 1.5mm x 60 # 005
      these are just the 1.5mm bolts so it looks like.
        • 18286
        Saw the Hobby easy ones there out of stock. The Czech Master ones are only bolt heads. I need the nuts on a bolt type....
        I found a place in Aussie land that has some but I can imagine getting stitched up on the post (and duties).
        Thanks for the links though.
          Have you tried these people? Not cheap though.
          Scale Hardware, the world's finest scale model fasteners
          Martin
            • 18286
            An interesting link Martin. Like you say, a bit pricey and for the amount I need I think it might be noted as a last resort. They sure have a good choice, but still trying to find 1,5mm... every thing is to small so far. Now I didn't think I would be saying that!
            • John
              • Mar 2004
              • 4677
              • John
              • Halifax
              Not very helpful for you but on Google the forum is placed 1st for the term "small nuts"
              www.scalemodelshop.co.uk
                Ian,
                Not sure if this is any help but best I can find.
                trythis
                Hope it's of some help
                  Does this mean you'll now start selling Viagra?
                    What dimension is the 1.5mm referring to?
                    Martin
                      • 18286
                      Oh technical question...lol
                      Erm Guilty. I was going by the size I read in an article. I can though say that I can imagine at the widest point; corner to corner if you like.
                      The job at hand is to add the missing bolts that hold the torpedo tubes on the deck of my MTB 77. Italerie sort of forgot them!
                      The foot has a width of just 2mm from edge to vertical part, so I would say that a maximum size of 1.9 across the points.
                      I have found a couple of places where I can get some but at a tenner for a pack of 20 - 25 and needing about a 100 I would like to keep my options open. I have found some Hex plastic profile that I might be able to make them from, but the idea of doing the amount I need and getting them the same.....:-/
                        Ian, not sure what you are after, but I use this guy for my ships fittings, he does very small threaded items, mostly brass though.
                        SPECIAL NUTS AND BOLTS - modellingtimbers.co.uk
                        Also try googling under 'miniature screw fasteners'
                        Cheers Derek
                          Nice, but....ouch!!
                          Martin
                          • Dustbin
                            • Jan 2009
                            • 121
                            Nut on a washer 1.6mm MC435079 | eBay
                            Try this one
                            Paul
                              Fiver for a hundred sounds good
                              Martin
