A new model airfield layout-More turf and the residents fly in !
Today I did a lot more of the turf areas consuming quite a bit of flock in the process,after experimenting I found that the best way to handle this material is as follows 1/ Paint the area with brown umber acrylic artists paint,you do not have to use artists quality I used System 3 which is a students grade that is adequate and is cheaper because it uses more filler to pad it out,being tacky and of PVA formulae it is ideal,give a generous coat 2/ Sprinkle on the flock,I mixed the colours this time to good effect 3/ Next with the tip of a large brush stab gently vertically into the flock,this pounces it into the paint nicely 4/ Allow to dry overnight and the next day with a piece of paper and a dry brush simply brush off any surplus onto the paper and recycle placing into a jam jar or similar.
I have never done any ballasting of track so decided to give it a try,firstly I puddled PVA adhesive between the sleepers and outside of the track,then sprinkled ballast between the sleepers and at the sides,I realised straight away that I had added too much gravel and with a dental flat tool scraped off the surplus then checked the run with a spare bogie wheel,I am learning the art of railroading ! next time I will try a different way by first laying the ballast dry into the gaps of the sleepers then mix up some thinned PVA and flood the gravel.
I need to get this right as there is a lot of track to cover eventually.
At the back of the layout I Adecided to add the industrial unit which also doubles up as the heliport including the air ambulance,the planned village will now be fabricated from the left to right of this on a removeable board as I need access to that particular area,I am planning something like some simple trestles positioned either end with the board butting up against the main layout,I will give that area some thought as I really would like to incorporate some rural houses of some type.
Meanwhile the aircraft have moved in ! a suitable selection of light aircraft and even a Wellington bomber as a cherished gate guard denoting the airfields past history as a bomber base.
Wonwinglo.
[ATTACH]28442.IPB[/ATTACH]
[ATTACH]28443.IPB[/ATTACH]
[ATTACH]28444.IPB[/ATTACH]
[ATTACH]28445.IPB[/ATTACH]
[ATTACH]28446.IPB[/ATTACH]
[ATTACH]28447.IPB[/ATTACH]
[ATTACH]28448.IPB[/ATTACH]
[ATTACH]28449.IPB[/ATTACH]
[ATTACH]28450.IPB[/ATTACH]
[ATTACH]28451.IPB[/ATTACH]
[ATTACH]28452.IPB[/ATTACH]
[ATTACH]28453.IPB[/ATTACH]
Wonwinglo.
o not proceed with Part 28 until the important issues with the
