Today I have had a right nightmare with the pe for some reason everything I made just would not work , the day started ok just fitting some steps to the boat deck of Warspite but that all changed when I began work on the cranes , I read the instructions which were prity straight forward but it was a case of you can't do step one until you've done step two and I ended up having to pull step one apart well I didn't intend to actually pull It apart it just fell apart , but I managed to piece it together and moved onto the crane arm , things started well just had to to bend the sides and afix the underside , now this is where I lost the plot ! The underside wouldn't fit properly and when it did it stuck to me finger and in removing it I knocked it out of position ! Anyway I managed to get it reasonably done not perfect but not too bad , I then put it to one side , I then returned to the crane and put a few little pieces on and I started getting over the frustration I had built up with the crane arm so picked up the crane arm only to find out I'd superglued it to the desk
