Wendall's 1/48 Raspberry Ripple Tornado
  • rickoshea52
    • Dec 2011
    • 4081
    • Rick
    #16
    I'd be inclined to keep the tabs at the top where the pylon mates against the wing and also keep or scratch build a replacement set of pads for the bottom where the stores attach. I think it might depend on what store is being carried, a quick google search for "boz pod pylon" brings up a variety of different fittings.
    I never worked on tonkas but occasionally we'd get a Nimrod with a boz/chaff pod still fitted into the hangar and I distinctly remember these steadies on the pylon. I haven't seen an example on a tonka but the gaps between the pylon and wing were sealed with speed tape on nimrods.
    • Wendall
      • Jun 2013
      • 918
      #17
      Cheers Rick, I'll leave them as they are then I think.
      • rickoshea52
        • Dec 2011
        • 4081
        • Rick
        #18
        I did a quick search and the top tabs should remain but the bottom tabs could be removed going by the pictures in the links below.
        http://rogerritter.com/images/aviation/Mi8-Tornado/File0013.jpg
        http://rogerritter.com/images/aviation/Mi8-Tornado/File0012.jpg
        http://www.zone-five.net/showthread.php?p=283224
        http://www.b-domke.de/AviationImages/Tornado/3421.html
          Nice work, this is going to be a good aircraft by the looks of it. Like your interior shots
          • Wendall
            • Jun 2013
            • 918
            #20
            Cheers Rick, I'll cut them off then I think
            Cheers Dougie.
            • Dave W
              • Jan 2011
              • 4713
              #21
              Originally posted by \
              After some advice please fellas! I can't find any definitive reference pics, am I right in thinking that theses sway brace? Thingys on the pylons should be removed on an RAF Tornado?
              [ATTACH]129329[/ATTACH] [ATTACH]129330[/ATTACH]
              Jason.
              I spent 7 years as a crew chief on a Saudi Tornado squadron.The pylons didn't have sway braces.Instead there was a mechanism built into the pylon that tightened the crutches if the store moved.Im assuming the RAF ones were the same .So I would cut off the sway braces.
              • Wendall
                • Jun 2013
                • 918
                #22
                7 years on them! I'll take that as gospel. Cheers Dave.
                • rickoshea52
                  • Dec 2011
                  • 4081
                  • Rick
                  #23
                  Further to Daves comments, I stumbled across this post on Britmodeller, the sway braces aren't present on RAF machines.
                  http://www.britmodeller.com/forums/index.php?/topic/234970425-revell-tornado-ids-question-want-to-build-raf-version/
