It's a kit that more or less builds itself! So much so that I've completed the major construction and got the primer on. I've used white because of the small scale. The paint on the original has been altered from the factory finish quite significantly and I'm going to attempt to replicate this,which requires the lighter greys to come through.A dark primer would make this more difficult.
No filler has been used in the making of this model
Underside (RLM 76) later,with a bit of luck.
