Colin's English Electric Lightning 1/32 Trumpeter
  • Steve Brodie
    • Sep 2014
    • 4652
    #31
    lovin the seat
    • Bigfoot57
      • Jun 2015
      • 1103
      #32
      Finally got the fuselage together some serious gaps need filling and smoothing but once done should look ok
      Regards
      Colin
      • Steve Brodie
        • Sep 2014
        • 4652
        #33
        lookin good, love the green radome
        • Bigfoot57
          • Jun 2015
          • 1103
          #34
          Steve that radome is a mixture of if recall 3 greens 2 browns 1 red and 2 greys and was applied on each whilst wet to hopefully get brownish tinged green colour which I matched to numerous photo's on the net and my reference books
          Regards
          Colin
          • colin m
            • 8927
            • Colin
            • Stafford, UK
            #35
            Originally posted by Bigfoot57
            Wait till you get to detailing the cockpit numerous swear words and hunting for bits of pe that ping out of the tweezers which I flattend literally with the application of a enginners ball pein hammer in the troublesome area wouldn't reccomend it only for therapeutic reasons
            Regards
            Colin
            If you really want to practice 'naughty' words, try 1:72 PE. I invented new 'naughty' word while working with this stuff.
            • Bigfoot57
              • Jun 2015
              • 1103
              #36
              Engine building time my god look at all the pe to go on the exterior of the model
              Regards
              Colin
              • peterairfix
                • Jul 2012
                • 11108
                #37
                Good luck with all that lot and I can hear the cursing already.
                • Bigfoot57
                  • Jun 2015
                  • 1103
                  #38
                  Engine parts now painted when dry assemble and add pe as required
                  Regards
                  Colin
                  • Bigfoot57
                    • Jun 2015
                    • 1103
                    #39
                    Another lousy fit for the engine assembly held in place by force with tape whilst the glue sets more filler required I reckon after it has stuck
                    Yep I was correct huge gap around engine mount and fuselage so more filler should look ok when sanded smooth and repainted etc While I was at it I went over the entire fuselage join and filled in all gaps ready for priming and finishing with foil thats the plan
                    Regards
                    Colin
                    • Bigfoot57
                      • Jun 2015
                      • 1103
                      #40
                      Latest update found I had to cut off the hinges to the airbrakes and then cement the airbrakes in closed position and then sand down the cut off hinges so they would fit back into the fuselage as the airbrakes were rarley if ever seen in the open position when the aircaft was at rest on the ground
                      Whilst I was at it I decided to paint the spine red as this kit will be foil covered no masking was deemed neccasry for this point
                      I also painted the engine exhaust and still have some pe to apply to finish them off
                      • flyjoe180
                        • Jan 2012
                        • 12661
                        • Joe
                        • Earth
                        #41
                        Coming along nicely Colin. Boy is this an epic battle and you're winning!
                        • Bigfoot57
                          • Jun 2015
                          • 1103
                          #42
                          Tonights simple task join the 2 tail pieces together really no this has to be the worst fitting pair of plastic mouldings in history as you can see from attached picture 6 clamps in attemp to seal the join which when it is set will have huge gaps in it requiring more filler I had actually painted these 2 items thinking a nice simple join and just a touch up now looks like a complete strip off and repaint I just hope the wings are better some hope!!!!
                          Fitted tailfin oh dear gap by the join to fuselage spine and all along bottom edge
                          • Bigfoot57
                            • Jun 2015
                            • 1103
                            #43
                            More filling like I said absolutely apalling fit as can be seen from these pictures
                            Hours later filler sanded off and 2nd coat of red applied looking much better now any remaing gaps should disapear when the foiling is done
                            Regards
                            Colin
                            • Bigfoot57
                              • Jun 2015
                              • 1103
                              #44
                              New seat arrived from France today look at the difference and thats before its painted the trumpeter eduard is utterly blown away by this moulding just hope my paint job does it justice
                              Regards
                              Colin
                              • Bigfoot57
                                • Jun 2015
                                • 1103
                                #45
                                Moved onto next stage foiling only done a small bit to see how it would go its not difficult not to my way of thinking you just need patience and a methodical way of doing the same thing over and over
                                The effect is to me way better than what I could achive with paint and it requires no priming just a clean plastic surface so the glue sticks to the foil
                                Regards
                                Colin
