Kubelwagon Type 82 - 1:35 - Tamiya
  • pjgtech
    • Dec 2023
    • 1266
    • Peter
    • Swale Kent UK
    Started this little vehicle couple of days ago.
    Fancied something a tad simpler than the last couple of more taxing builds (for me), eg: diorama's.
    This will hopefully be a nice easy and simple build.....Lol, famous last words I bet!
    So far, as you would expect with a modern Tamiya kit, fit is excellent, no flash to speak of, very little tidying up / fettling needed, etc.
    Here's the box, sprue photos, NB: I had already primed some bits on the sprue at this point....
Name:	Kubelwagon 4apr25.jpg
Name:	kubelwagon 14apr25  (1).jpg
Name:	kubelwagon 14apr25  (2).jpg
Name:	kubelwagon 14apr25  (3).jpg
  • pjgtech
    • Dec 2023
    • 1266
    • Peter
    • Swale Kent UK
    More progress was made yesterday, mainly priming and painting most things.
    There appears to be two basic paint schemes for this vehicle, a green/yellow camo and a German Grey. I have opted for the German grey.
    More photos of progress made yesterday.....
Name:	kubelwagon 14apr25  (6).jpg
Name:	kubelwagon 14apr25  (7).jpg
Name:	kubelwagon 14apr25  (8).jpg
    • pjgtech
      • Dec 2023
      • 1266
      • Peter
      • Swale Kent UK
      This morning I started on the actual build process, going ok so far, slow but steady.....
      Engine placed in main chassis...
      Click image for larger version  Name:	kubelwagon 16apr25  (1).jpg Views:	0 Size:	405.6 KB ID:	1255406
      Front bonnet / hood assembled....
      Click image for larger version  Name:	kubelwagon 16apr25  (2).jpg Views:	0 Size:	800.6 KB ID:	1255407
      NB: the front rod/tow bar on the sprue was too short, so I improvised with a short length of brass rod and attached via CA.
      Under chassis bits added, front axel etc...
      Click image for larger version  Name:	kubelwagon 16apr25  (3).jpg Views:	0 Size:	413.2 KB ID:	1255408
      After initially priming parts on the sprue, I then proceeded to paint most bits also, yes, I don't mind POS (Painting On Sprue) personally.
      Click image for larger version  Name:	kubelwagon 16apr25  (4).jpg Views:	0 Size:	369.0 KB ID:	1255409
      Click image for larger version  Name:	kubelwagon 16apr25  (5).jpg Views:	0 Size:	403.4 KB ID:	1255410
      Then on to more assembly, so the rear bulkhead was fitted....
      Click image for larger version  Name:	kubelwagon 16apr25  (6).jpg Views:	0 Size:	341.9 KB ID:	1255411
      Then the main upper bodywork was assembled....
      Click image for larger version  Name:	kubelwagon 16apr25  (7).jpg Views:	0 Size:	363.3 KB ID:	1255412
      Some more parts were removed from the sprue, ready for more assembly later, eg: seats, etc.
      Click image for larger version  Name:	kubelwagon 16apr25  (8).jpg Views:	0 Size:	298.8 KB ID:	1255413
      And finally the upper bodywork was married to the lower chassis.... seems to fit ok, its now being left alone for a bit before I proceed further...
      Click image for larger version  Name:	kubelwagon 16apr25  (9).jpg Views:	0 Size:	354.7 KB ID:	1255414
      Its certainly been fairly easy, simple to follow, and no issues (so far), I'm liking this little kit.
      • PaulTRose
        • Jun 2013
        • 6935
        • Tattooine
        This is a great little kit.......i certainly enjoyed doing it a few years ago
        Per Ardua
        • pjgtech
          • Dec 2023
          • 1266
          • Peter
          • Swale Kent UK
          The front bumper, tow bar came off whilst glueing the bodywork to the chassis, Doh!
          So thats now been re-attached....
Name:	kubelwagon 17apr25  (1).jpg
          Dash installed and pedals, gear lever, steering column, etc...
Name:	kubelwagon 17apr25  (3).jpg
          And then spare wheel attached, plus rear canopy and frame and the seats, slowly getting there....
Name:	kubelwagon 17apr25  (5).jpg
Name:	kubelwagon 17apr25  (6).jpg
          • pjgtech
            • Dec 2023
            • 1266
            • Peter
            • Swale Kent UK
            Did a bit more yesterday and this morning.
            Wheels now on, and doors added, one is left open (as the included driver's pose is sitting with one leg out and his arm resting on the open door.)
            NB: Driver not yet finished / painted.
            Pioneer tool added, along with headlights, rear grab rail, and windscreen assembled with clear screen.
            Click image for larger version  Name:	Kubelwagon 18apr25  (1).jpg Views:	0 Size:	436.3 KB ID:	1255606
            Click image for larger version  Name:	Kubelwagon 18apr25  (2).jpg Views:	0 Size:	415.3 KB ID:	1255607
            Also added the indicators and side mounted rear view mirror....
            Click image for larger version  Name:	Kubelwagon 18apr25  (3).jpg Views:	0 Size:	449.6 KB ID:	1255608
            Click image for larger version  Name:	Kubelwagon 18apr25  (4).jpg Views:	0 Size:	381.4 KB ID:	1255609
            Below pic is dry run of the driver and windscreen, but both are not yet fixed, also need to add the steering wheel.
            Click image for larger version  Name:	Kubelwagon 18apr25  (5).jpg Views:	0 Size:	685.7 KB ID:	1255610
            Not decided whether to have screen up or down yet, may also add some stowage/luggage, and will also be applying some weathering and highlighting, so not quite finished yet....
            • pjgtech
              • Dec 2023
              • 1266
              • Peter
              • Swale Kent UK
              This mornings update.....
              She is all built now, and I have painted everything and added a few highlights, bits of wear, etc, put a gloss coat on and applied some transfers, but have not yet started the weathering yet.
              Pics....
              Click image for larger version  Name:	kubelwagon 20apr25  (1).jpg Views:	0 Size:	492.2 KB ID:	1255794
              Click image for larger version  Name:	kubelwagon 20apr25  (2).jpg Views:	0 Size:	359.9 KB ID:	1255795
              Click image for larger version  Name:	kubelwagon 20apr25  (3).jpg Views:	0 Size:	359.0 KB ID:	1255796
              Click image for larger version  Name:	kubelwagon 20apr25  (4).jpg Views:	0 Size:	416.8 KB ID:	1255797
              Click image for larger version  Name:	kubelwagon 20apr25  (6).jpg Views:	0 Size:	442.3 KB ID:	1255798
              Click image for larger version  Name:	kubelwagon 20apr25  (7).jpg Views:	0 Size:	617.7 KB ID:	1255799
              • Airborne01
                • Mar 2021
                • 4250
                • Steve
                • Essex
                Coming along nicely, will you give it a coat of matt varnish once complete?
                • pjgtech
                  pjgtech commented
                  Editing a comment
                  yes, should get it done later today.... 8-)
              • pjgtech
                • Dec 2023
                • 1266
                • Peter
                • Swale Kent UK
                Think this one is now done....
                See pics.....
Name:	kubelwagon 22apr25  (1).jpg
Name:	kubelwagon 22apr25  (2).jpg
Name:	kubelwagon 22apr25  (4).jpg
Name:	kubelwagon 22apr25  (5).jpg
Name:	kubelwagon 22apr25  (7).jpg
                I am using Humbrol Satin Matt clear varnish (rattle can) but still seems to be a bit glossy?
                Can anyone recommend a better / flatter matt varnish spray can type?
                NB: I do also have some other matt (paint on) varnish, eg: Tamiya, but I have now mostly moved to rattle cans for primer and varnish, in conjunction with my paint booth/filter.
                • Airborne01
                  • Mar 2021
                  • 4250
                  • Steve
                  • Essex
                  Tamiya matt, Humbrol/Airfix matt and Army Painter all work well mate - give 'em a good shake first, especially the AP stuff!
                  • scottie3158
                    • 14490
                    • Holbeach
                    Great result. I use AK ultra matt.
                    • pjgtech
                      • Dec 2023
                      • 1266
                      • Peter
                      • Swale Kent UK
                      Ok, so I redid the final coat using Tamiya Flat matt clear varnish coat (via rattle can) and it is now much less glossy, so looks a lot better.
                      I think I just did not shake the can enough when I used the Humbrol clear varnish?
                      Anyway final (final) pics.... Cheers
Name:	kubelwagon type82 final pics 24apr25 (1).jpg
Name:	kubelwagon type82 final pics 24apr25 (11).jpg
Name:	kubelwagon type82 final pics 24apr25 (12).jpg
Name:	kubelwagon type82 final pics 24apr25 (13).jpg
Name:	kubelwagon type82 final pics 24apr25 (18).jpg
Name:	kubelwagon type82 final pics 24apr25 (15).jpg
                        • 16075
                        Very nice indeed. Much nicer with a matt coat.
                        • Stefee
                          • Feb 2023
                          • 966
                          • Stefan
                          • Hemel Hempstead
                          That is a lovely rendition especially since the matter coat was applied. Like your weathering and dirtying up but just can't do it to my builds.
                          • pjgtech
                            pjgtech commented
                            Editing a comment
                            I still don't think my weathering is that good! Its better than it was, but I'm still learning bit by bit, but some of the peeps on here do some amazing work..... 8-)
                        • pjgtech
                          • Dec 2023
                          • 1266
                          • Peter
                          • Swale Kent UK
                          Last little thing that I have added to the Kubelwagon, just a large rolled camo net, (made from old Bandage gauze) and a couple of fuel cans.
Name:	Kubelwagon final apr25.jpg
