Tamiya M20
  • scottie3158
    • 14583
    • Holbeach
    #211
    Originally posted by stu1664
    Your PE is on another level Scottie - detailing is superb!!!
    Stu, Thanks a lot mate and a warm welcome to the forum. I look forward to seeing you and your work about the forum in the future.
    • scottie3158
      • 14583
      • Holbeach
      #212
      Did a little on the stowage today not sure if I am 100% happy but that is how it stands at the moment I might rip it of and start afresh I will see how it dries. Comments or suggestions welcome.
      cheers
      Scottie
      • stu1664
        • Apr 2019
        • 99
        #213
        [ATTACH=CONFIG]n1091921[/ATTACH]
        [ATTACH=CONFIG]n1091922[/ATTACH]
        [ATTACH=CONFIG]n1091923[/ATTACH]
        [ATTACH=CONFIG]n1091924[/ATTACH]
        cheers
        Scottie
        Hi Scottie
        How do you actually go putting PE together as its blemish free - in my case its normally swamped in glue with an erroneous digit stuck to it!!
        • scottie3158
          • 14583
          • Holbeach
          #214
          Hi Stuart,
          Normally with a lot of swearing lol. Firstly the PE gets washed in warm soapy water. Before removing it from the fret study the part and the instructions as to how to fold the part as its not always clear. Next work out the sequence of folds. Then with a sharp scalpel I scratch the parts to be joined to give a good keyed surface. When it comes to the glue less is more don't worry to much about any over spill as this can be scraped off with a sharp blade. Then finally when completely dry I use a fibre pen to clean everything. But wear a mask as the fibres can cause irritation. I hope this helps.
          • stu1664
            • Apr 2019
            • 99
            #215
            Hi Scottie
            Thanks for the heads up - will follow your lead and have plenty of medication on standby!:tongue-out3:
            • scottie3158
              • 14583
              • Holbeach
              #216
              Hi Scottie
              I forgot to say a good pair of tweezers and the ability to grow a third hand helps as well :tongue-out3:
              • Strenko J
                • May 2018
                • 752
                • Joe
                • Pittsburgh PA
                #217
                It would be a shame to cover up that MG with a full cover.. maybe peel it back a bit to show off some of the bling?? Just a thought.... and the other stowage fits perfectly and looks fantastic your scratchery is a work of art
                • SimonT
                  • 2824
                  #218
                  Coming on a treat Scottie :thumb2:
                    • 19106
                    Looking great Scottie, fantastic work. A hint, if I may....if you use a fibreglass scratch brush keep a saucer of water with a drop of washing up liquid in it on your bench and dip the brush in just before you use it....hey presto, no flying fibres....
                    • Steve Jones
                      • 6615
                      #220
                      Nice work Scottie. Liking the tarp's
                      • Steven000
                        • Aug 2018
                        • 2893
                        • Steven
                        • Belgium
                        #221
                        Nice details Scottie! I also like the idea of the plastic foil etc :thumb2:
                        Cheers, Steven
                          Added the pioneer tools from the spares box, and the mine rack to one side. The Hull is now very nearly done. So will be moving on to the MG mount soon. I have also given the base some thought and I think the germs of an idea are brewing.
                          As always comments good and bad welcome.
                          [ATTACH=CONFIG]n1091232[/ATTACH]
                          [ATTACH=CONFIG]n1091233[/ATTACH]
                          [ATTACH=CONFIG]n1091234[/ATTACH]
                          cheers
                          Scottie
                          Sad that I can't manage this standard,:crying: great job Paul.
                          • Mr Bowcat
                            SMF Supporter
                            • Dec 2016
                            • 4693
                            • Bob
                            • London
                            #223
                            Loving the MG Paul, but please dont cover it all up with a tarp, it looks too good.
                            Si vis pacem, para bellum.
                            • BigGreg
                              • 2186
                              #224
                              If I may... don't cover the beautiful made detailed 50 cal.... and as usual you are delivering STUNNING work..
                                Hi Paul stunning work as usual , i agree with everyone please don't cover up the 50 cal.
                                Pete.
