Scotties Sd.Kfz. 10/5
  • rtfoe
    • 9231
    • Richard
    • Shah Alam, Malaysia
    #136
    Amazing stuff Scottie...gotta do something about the detail on the finger and thumb scaling by desausaging it. :smiling2: Like the others have said either a mesh cage or a sack of some sought to catch the empty shells. Most I've seen don't have them. Can't recall the one I saw at the AWM.
    • scottie3158
      • 14638
      • Holbeach
      #137
      Originally posted by outrunner
      Your detail never ceases to amaze me Paul, I have enough trouble building out of the box models.
      Andy.
      Andy, to kind mate, trust me you don't have any trouble.
      Originally posted by adt70hk
      Now that really is rather good....top notch work!! It's at that level of additions and scratchery that it almost seems a shame to paint.
      ATB.
      Andrew, I agree mate some peoples details for example Ayrtom should never be painted.
      Luv it Scottie. Top work my friend
      Steve, really appreciated mate thank you.
      Originally posted by Mini Me
      Jus Booful man.....even though it lacks pewter, I think Mr. "T" would have been proud of you......I do miss him. :thumb2: Rick H.
      Rick, I hope so mate, he amongst others are responsible for my journey to the dark side. And your right I miss his imput and amazing builds.
      Originally posted by wotan
      Scottie
      Is there not some sort of netting sack attached to collect the spent cartridges.?
      John. I think this was not fitted to all versions and I would struggle to fit one now with the shields in place.
      Originally posted by minitnkr
      I wasn't going to mention it as it wasn't always present, but a wire mesh cage was affixed to some.
      Paul, I think your right there was no mention of it in the instructions.
      Seen it both ways.....I prefer it without the squirrel cage as you can see more of the Gun.
      Rick, I tend to agree I think it looks better without as well.
      Originally posted by Mickc1440
      That looks the dogs mate
      Mick, cheers Matey glad you approve.
      Originally posted by BigGreg
      Paul...l mean Paul your level of detailling vehicles is absolutely FANTASTIC...more more l need to see moooore....
      Thanks Greg it's fun adding the detail.
      Originally posted by Jim R
      Hi Scottie
      Flak 38 looks superb. You are right about the more to scale thickness shields - the PE just looks so much better.
      Jim, the kit shields would scale up to half an anvil thick lol.
      Thanks Richard, glad you like it.
      • Mini Me
        • Jun 2018
        • 10711
        #138
        Couldn't agree more, Mr. "T" was my best critic.........he always had a way of pushing me to go a little further with a build to get just a bit more out of it.
        Rick H.
        • tr1ckey66
          • Mar 2009
          • 3592
          #139
          Exquiste work Paul. The 20mm looks terrific!
          P
          • scottie3158
            • 14638
            • Holbeach
            #140
            Rick H.
            Your right he would critic/advise but never insult. He would even detail the details lol.
            P
            Paul, very kind of you mate thank you.
            • Graeme C.
              • 1628
              • Graeme
              • UK
              #141
              The gun is spot on Paul, the etch shields, rivet detail, the extras all make the difference. I don't know how you have the patience.
              • Lee Drennen
                • 7738
                #142
                Rick H.
                Yes he was the kid on the playground that dared you to chew the gum on the ground. You didn’t want to go that far but you knew you had to if you wanted to keep your ranks.
                • Lee Drennen
                  • 7738
                  #143
                  Paul looks outstanding as always. Love these guns
                  • scottie3158
                    • 14638
                    • Holbeach
                    #144
                    Thank you Graeme, trust me I turn the air blue sometimes.
                    Very true mate :smiling::smiling:
                    Thank you mate glad you like it.
                    • scottie3158
                      • 14638
                      • Holbeach
                      #145
                      I built up the tracks these were the Masterclub offerings and a lot better than the kit ones each link had two pins and a separate track pad. The good news was there are only 39 links per side if you count the links in the instructions, but I may have to add more later. Tension will be correct when the top run touches the centre road wheel.
                      Next work started on the Sd.Ah. 51 trailer. Not a bad little kit and you get two in the box. The side panels were given a tweak.
                      Before.
                      after
                      The rods will be trimmed to length later.
                      cheers
                      Scottie
                      • scottie3158
                        • 14638
                        • Holbeach
                        #146
                        had some fun tinkering with the details. Items have been added from the PE stash and scratched from plastic and pewter. They are not 100% accurate but represent the detail that should be there
                        I cut off some of the internal shelf detail and replaced it with plastic sheet. The kit part had some magazines and loose rounds moulded in and I wanted the space to add my own details later.
                        cheers
                        Scottie
                          • 16311
                          Hi Scottie
                          Impressive stuff. Even if things are not 100% accurate the 'sharpness' of your additions makes it worth the time and effort. Small detail moulded in styrene is often quite soft - like in your first photo.
                          jim
                          • Mickc1440
                            • 4859
                            #148
                            More top drawer stuff mate, who cares if they're not 100% they look superb
                            • grumpa
                              • Jan 2015
                              • 6142
                              #149
                              Why it's absolute madness!...... Awesome detailing gone completely out of control!
                              Will someone stop him!?
                              Don't even think about it!....carry on Your Awesomeness!
                              Love your work as always....Jim.
                              • adt70hk
                                • Sep 2019
                                • 10554
                                #150
                                Great work Scottie.... Keep it up.
