Steve's 1:48 Revell Apollo 11 "Eagle" lunar lander
Well Steve this is certainly a kit I'll avoid. Looks like a challenge. Corrections and additions needed. Luckily it looks like you're up to the task. Coming on nicely.
Cheers Jim. Will do my best with it.
Some progress, bit of a curates egg, good in places. So after applying prime the model was sprayed silver and then masked off for the bare metal joints of the panels bits. Ive highlighted some of the bare metal areas that I am trying to achieve.
Click image for larger version  Name:	thumbnail.jpg Views:	0 Size:	177.1 KB ID:	1259937
So I ended up with this.
Click image for larger version  Name:	IMGP0071.jpg Views:	0 Size:	246.1 KB ID:	1259938
Next I mixed up a paint colour to match the greeny tinted aluminium colour of the actual lunar module. I then sprayed over the whole thing and got this.
Click image for larger version  Name:	IMGP0075.jpg Views:	0 Size:	231.2 KB ID:	1259939
Next was to then apply the second phase of masking to protect the green ready for application of the grey.
Click image for larger version  Name:	IMGP0077.jpg Views:	0 Size:	194.7 KB ID:	1259940
Then the model was sprayed grey and when dry the third mask application was put on ready for the final spray of black.
Click image for larger version  Name:	IMGP0080.jpg Views:	0 Size:	248.2 KB ID:	1259941
Black was then applied.
Click image for larger version  Name:	IMGP0083.jpg Views:	0 Size:	133.6 KB ID:	1259942
And then when dry all masking removed for final result. Overall quite pleased but its obvious that the chrome bits are a little too thick Despite my best efforts I just could not cut it any thinner so this will have to do.
Click image for larger version  Name:	IMGP0094.jpg Views:	0 Size:	145.5 KB ID:	1259943
Click image for larger version  Name:	IMGP0096.jpg Views:	0 Size:	121.5 KB ID:	1259944
Click image for larger version  Name:	IMGP0097.jpg Views:	0 Size:	133.6 KB ID:	1259945
Quite a bit of tidying up to do particularly around the windows where the liquid mask was applied. I have also stuck a bit of plastic on the decent stage. Dont know what it was for but it will go under some foil to replicate this.
Click image for larger version  Name:	thumbnail (3).jpg Views:	0 Size:	264.6 KB ID:	1259946
Click image for larger version  Name:	IMGP0082.jpg Views:	0 Size:	239.0 KB ID:	1259947
Thats it for now. I thought this was going to be a quick build but it is taking longer than anticipated. The painting alone has taken 4 days so far because for having to wait for paints to dry etc.
Great job! I'm loving the scratch building. Will you be using gold leaf for some of the heat shield?
I dont think I will come anyway near as good as your finished model Stefan. I have been using it as a reference along with the files you sent me. They are quite a tricky build.
yes George. At presant I have sprayed the lower stage black. It will then get a coat of satin on the black and then I will attach the gold foil.
    • I dont think I will come anyway near as good as your finished model Stefan. I have been using it as a reference along with the files you sent me. They are quite a tricky build.
    Thanks for the compliment but yours is looking mighty fine to me, I never even thought about the edges being uncoated aluminium.
    It is a tricky build but I got off lightly compared to you as my kit was 10 years newer and has obviously been modified and extra parts supplied.
Thanks Steve. Getting there with it now.
I havent gone to sleep on this one chaps its just been a long and frustrating experience with the foil. First problem was I have somehow managed through the years of having this kit to loose a piece that was part of the landing gear. I have highlighted the piece.
So I had to fabricate one out of piano wire. Bit of a bodge job but when covered with foil it blends in OK with the others. Then the week has been spent getting the foil on. Looks a bit rough but I guess the actual vehicle looked a bit rough as well.
I had to fabricate the black bits on the legs and used gold thread for the foil ties on the legs. I dont know the actual names of these bits.
I am pleased with how the undulations in the foils and insulation have turned out. The landing gear feet were a problem. I was going to foil them but everytime I tried to push the foil into the foot the foil just kept tearing so they got a coat of gold spray instead. My patience ran out. Now onto the final stages of adding the cluster thrusters, radar/radio domes, ladders etc. Then I just have the 4 thruster deflectors to make and attach.
Thanks for following.
Looking really excellent - wish you had mentioned the missing parts earlier as I have a couple of spares but your "bodge" looks absolutely fine.
Cheers Joe. I can see light at the end of the tunnel.
