h m s victory part build
    H m s victory
    Update planking progress three lines .
    • flyjoe180
      • Jan 2012
      • 12938
      • Joe
      • Earth
      #17
      That's coming along nicely James.
        H m s victory
        Update I  have  had  some set backs , breaks and I am having  a overhaul , coz  things dont sit right
        Distorstion  on hull , before adding
        More need to know all ok x thank you meantime measureing stick out .more to come
        Just  want to be sure all ok once set  no go back , ha
          hi ship  mates
                              i have had some personal set backs  hence no updates , or build  plus a couple  of mistakes i have noticed  and a break in one off  the  rib  surports  still trying to find a path or replace ,but  will be dissembling  certain parts  which i want to  avoid  if possible .
          • peterairfix
            • Jul 2012
            • 11139
            #20
            I can't see much wrong with your work,looks much the same as mine did at the same stage looking forward to more pics when you have it sorted
              left side third  rib  broken  ,re glued  but weak  don't know if it'll  take pressure  i have replacement part   , unless i can find a way of  attaching  something to strengthen broken part
              • BBdave
                • Aug 2014
                • 825
                #22
                You might find dampening the planks first will ease the bending and reduce the stresses.
                  sounds  good  to me , now  going over  it's been  down  tools last  few weeks but hoping to   do more weekend .
                  second  deck third rip in floor surport broken  glued but not firm
                    hello
                               did  some  work on victory over  the weekend more planking  checking   all round to see  in alignment  plus assembly guns   primed  awaiting  top coat
                    • Snowman
                      • Oct 2014
                      • 2112
                      #25
                      That is very cool!
                        This is great stuff; keep going mate!
                          With regards the planking, if you have access to a steam iron if you run the steam iron over the section you want to bend and gently lift the other end you can get very acute bends without the plank snapping.
                            WHat I do for the planking is to use a length of plastic tube from a plumbing store with a twist cap at both ends.  Put the planks in the tube with hot water, so they are thoroughly soaked, it will make bending the planks easier.
                            • monica
                              • Oct 2013
                              • 15169
                              #29
                              I was chatting to a chap,about planking ,and he said they use bleach as well,
                              I have not gone into research about it,
                              and I do real like Graham ,method to sock the planks,
                                Update ,painted upper deck cut ends off  sanded down ,alignment check , cannons painting  in progress  .
