h m s victory part build
    really nice james ,
      Progress ,assembly of cannons , tidyed up planking checked alignment  ,
        Victory , started gun port holes , alignment check .
        Check of gaps between planks .[ATTACH]270642[/ATTACH][ATTACH]270642[/ATTACH] [ATTACH]270644[/ATTACH][ATTACH]270645[/ATTACH]
          hello ship mates captain cryton more done over weekend and yesterday,
          cannon's assembly painted anchor's launch's in progress x
          [ATTACH]270874[/ATTACH] [ATTACH]270874[/ATTACH] [ATTACH]270875[/ATTACH] [ATTACH]270876[/ATTACH] [ATTACH]270877[/ATTACH]
            captain [ATTACH]271104[/ATTACH] [ATTACH]271105[/ATTACH] [ATTACH]271106[/ATTACH]
            hi ship mates , some more progress on victory more planking over weekend , working on cannon hole's tricky part and hair pulling as wood , braking thank goodness for the rum and spare wood , from sovereign of the sea which i would love to have but a start stop project now buried now victory , on the dry dock .more to come also working on yacht , planking oars etc
            • monica
              • Oct 2013
              • 15169
              #36
              progressing along very nicely ,James,that's a lot of gun ports,your planking is looking
              good,not an easy thing to do,
                hi monica
                arr there not cutting them out x three decks both side's plus any pressure planking comes' away hence ive glued outside to toughen and drilling center then it's a filing down square , time is a factor that and hair which i haven't got so plenty off rum haha or coffee ,if i was drinking rum there 'd be circler , finished yachet keel and oar hole's now priming and placeing inner deck plate before painting possably weekend with that in between more planking , too be done regards cryton .
                • monica
                  • Oct 2013
                  • 15169
                  #38
                  will be all worth it in the end,will be a stunning looking ship,
                    well that is defo the plan thats why there's no time limit on build xx
                      Looking good James, still got to cut out my gun port's on the SotS.
                      But I'm in no rush.
                      Hope u don't mined the pic.
                      [ATTACH]271285[/ATTACH]
                      Keep the pic's coming.
                        not at all , clean fluss planking there ,and envy i started this project as you three years ago but had too stop due too funds got as far as part planking parts 19 sots but just binned ,have kept wood as same size as victory as you see tricky cutting wood looking into easy cleaner way at moment , as time is needed second side now working on four port holes cut awaiting sanding looking into too help with that too nice work so far will keep an eye time for the rum or coffee , more work later when home ,cryton
                          victory update ,.
                          cannon's assembley yhacts x three awaitng inner planking before painting rub down victory working on cannon bays' at present tricky some wood have broken so replaceing [ATTACH]271555[/ATTACH][ATTACH]271556[/ATTACH][ATTACH]271557[/ATTACH]
                          • peterairfix
                            • Jul 2012
                            • 11139
                            #43
                            Keep up the good work a the rate your going you might be finished before me
                              Hms victory
                              More painting on yhact , cannons
                                hello ship mate's
                                haven't been well lately ,going over work were i left off and built some more cannon's hopefully more work on main build over weekend , loving the work on site fantastic will get around to seeing all progress .o_O[ATTACH]279154[/ATTACH][ATTACH]279155[/ATTACH]
