  • boatman
    • Nov 2018
    • 14600
    • christopher
    • NORFOLK UK
    #1741
    Originally posted by sootysue
    It's looking good to me Chris.
    HI Sue glad you think so but im not really happy with it but hopefully it will look ok when sprayed grey an thanks for lookin in stay safe
    chris
    • boatman
      • Nov 2018
      • 14600
      • christopher
      • NORFOLK UK
      #1742
      close up shot Click image for larger version
      • boatman
        • Nov 2018
        • 14600
        • christopher
        • NORFOLK UK
        #1743
        strb side shot an these pipesClick image for larger version
ID:	1141288 were little buggers to get the right angels before i gluded them in place an had to be carefull with the glue as the funnell must come off
        • boatman
          • Nov 2018
          • 14600
          • christopher
          • NORFOLK UK
          #1744
          • boatman
            • Nov 2018
            • 14600
            • christopher
            • NORFOLK UK
            #1745
            now shots of it mounted on the main 01 deck Click image for larger version
            • boatman
              • Nov 2018
              • 14600
              • christopher
              • NORFOLK UK
              #1746
              • boatman
                • Nov 2018
                • 14600
                • christopher
                • NORFOLK UK
                #1747
                an port side angle shot Click image for larger version
                • boatman
                  • Nov 2018
                  • 14600
                  • christopher
                  • NORFOLK UK
                  #1748
                  proper port side shotClick image for larger version
                  • scottie3158
                    • 14640
                    • Holbeach
                    #1749
                    Chris,
                    One thing you could try is to put a spring inside the tube to support the walls as you try and bend them. like a plumbers spring. Or nicking the inside of the bend.
                    • boatman
                      • Nov 2018
                      • 14600
                      • christopher
                      • NORFOLK UK
                      #1750
                      an here in the last pic today a shot of this small gantry platform an this was a devil to build but hey it worked out ok an its only 1/4 of an inch depth an talk about fiddley an in case anyone is wondering where the wires are for the Anti /collishion lights they are goin down inside the funnell an at the moment this funnell is a dummy but if i have the room i may buy another smoke unit so both funnells smoke or steam but will see on that Click image for larger version
                      • boatman
                        • Nov 2018
                        • 14600
                        • christopher
                        • NORFOLK UK
                        #1751
                        Chris,
                        YES Scottie very good idea on that but this lot is all glued down now but i might try your idea on the front funnel pipes but the bends are so tight i would have loved to done these in brass tubein but i havnt got the bendin tools to do this
                          • 18302
                          Not sure of the diameter of the pipes, but if you used a bendy straw, i
                          I'm guessing 6-7 mm? If you can get to a garden centre of flower shop, you can get soft bendy wire covered with a soft 'rubbery ' plastic. Might be something you could use...
                          • boatman
                            • Nov 2018
                            • 14600
                            • christopher
                            • NORFOLK UK
                            #1753
                            HI Ian cheers for that idea but ive now only got to fit the front funnel tube an they are very easy an short nothing like the rear ones as by rights the big tubes shoild be about 2mm bigger in diameiter but i think i looks a bit weird to me as its the black tubes standing out against the white funnell plasticard so i think it will all look ok when it in grey an it matches up in colour an looking at the plans these pipes wont be seen much as they will have the seacat missle lauches an the target directors in front of them so no worries
                            but cheers for havin a look in
                            an same to all you guys an gals
                            stay safe
                            chris
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #1754
                              Looks fine to me Chris......I do see from the plan sheet beside the funnel that the tubes are larger in diameter, considering what you had to work with, it came out very well. Rick H.
                              • boatman
                                • Nov 2018
                                • 14600
                                • christopher
                                • NORFOLK UK
                                #1755
                                Yep. Looks good to me mate. As Paul says, what aren’t you happy with? May be you’ve been too close to it and need a change Before coming back and finish8ng?
                                NO thats not the problem Tim its just the pipes should be 2mm bigger in diameter but they will now do as they wont hardly be seen
                                CHEERS for lookin
                                chris
