  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #2371
    an ive made it so that it folds back on itself so no damage in transport an when im ready to lay it out all ive got to do is just fold it back over into it natural pose as this crane lifts all the ships boats an launches Click image for larger version
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #2372
      an back in to the normal postion lookin here at the underside of the jib Click image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #2373
        an it has lights fited on the jib one red flashin anti collishin 2mm light led an two white 2mm leds look down lights for the crane operator to see what he lifting an where Click image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #2374
          an side view on the light an jib but this will carry on tomorrow as ive now got to build the crane mounting an fit ont the eletric plugs as this will all lift off when done Click image for larger version
          • stillp
            • 8290
            • Pete
            • Rugby
            #2375
            Wow! That crane is a model in itself!
            • GerryW
              • Feb 2021
              • 1757
              #2376
              Brilliant work there, mind-blowing!
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #2377
                OH THANKS Pete yea it took some building but im pleased with how its turning out an its not finished yet as more work on it tomorrow to build the base an mounting cheers chris
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #2378
                  an thanks gerry i enjoyed building it love a challenge does me lol
                  chris
                  • Mini Me
                    • Jun 2018
                    • 10711
                    #2379
                    Nice work on the crane Chris.........and a really nice feature being able to fold it up and stow it for transport.
                    Now you mentioned lights for the crane operator......will there be a crane operator on board and will this crane be powered up so's you can use it? :thinking: Rick H.
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #2380
                      HI Rick yes the lights will work an i will fit a operator in the cranes mounting but no im not goin to fit motors an such to make the crane work as to much top wheight as its all getting to heavy with all the brass jib an such an i cant see much point in doin so
                      as all that will happen is up an lowering the jib an turning about a couple of inches an to try an fit all motors an such does not seem worth it to me as there is still so much to fit on this ship i know that sounds dissapointing as i like to make things work but on this its not but im makin it so that the crane will lift off so i could have a change of heart an make it work but i mainly need Rick TO SEE HOW SHE FLOATS AS I DONT WANT TO GO OVER TOP WHEIGHT if you see what i mean but a very good question indeed an i'll keep it in mind if i can do this later on if i can but will see on it
                      ATB Chris
                      • adt70hk
                        • Sep 2019
                        • 10542
                        #2381
                        Hi Chris
                        Just had a catch-up. That is coming on very nicely indeed. The crane is a major piece of PE work and is looking very good indeed.
                        ATB.
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #2382
                          Originally posted by adt70hk
                          Hi Chris
                          ATB.
                          AN HI Andrew yea things are getting built an that crane an Rick came up with a very good question will the crane work an :thinking: id love to get the crane to work after thinking through Ricks idea as at the time of building this jib i had thoughts of it bein static but now the more i think on it the more id love to have it working as the jib is quite big but main problem as i said to Rick WITH BRASS its very heavy an i would have to source up a minatrure whinch an then turning the crane an motors are fairly heavy BUT Rick's sown the seed in my mind an i
                          • boatman
                            • Nov 2018
                            • 14498
                            • christopher
                            • NORFOLK UK
                            #2383
                            Sorry all p/c has thrown a wobbley
                            AN HI Andrew yea things are getting built an that crane an Rick came up with a very good question will the crane work an :thinking: id love to get the crane to work after thinking through Ricks idea as at the time of building this jib i had thoughts of it bein static but now the more i think on it the more id love to have it working as the jib is quite big but main problem as i said to Rick WITH BRASS its very heavy an i would have to source up a minatrure whinch an then turning the crane an motors are fairly heavy BUT Rick's sown the seed in my mind an i will have a lot of thought on this subject
                            ATB chris
                            • Steven000
                              • Aug 2018
                              • 2891
                              • Steven
                              • Belgium
                              #2384
                              Nice crane, looks great Chris! :thumb2:
                              Steven
                              • boatman
                                • Nov 2018
                                • 14498
                                • christopher
                                • NORFOLK UK
                                #2385
                                Steven
                                CHEERS Steven
                                chris
