BOATMAN's USS NIMITZ CVN 68 BUILD IN 1/144 SCALE
  • boatman
    • Nov 2018
    • 14598
    • christopher
    • NORFOLK UK
    #256
Name:	carrier build200.jpg
    • boatman
      • Nov 2018
      • 14598
      • christopher
      • NORFOLK UK
      #257
Name:	carrier build201.jpg
      • boatman
        • Nov 2018
        • 14598
        • christopher
        • NORFOLK UK
        #258
        In the test tank again to check for balance an leaks an to see how far she is off her W/LClick image for larger version
Name:	carrier build202.jpg
        • boatman
          • Nov 2018
          • 14598
          • christopher
          • NORFOLK UK
          #259
          STILL testing on balanceClick image for larger version
Name:	carrier build203.jpg
          • boatman
            • Nov 2018
            • 14598
            • christopher
            • NORFOLK UK
            #260
            An still balance testing as more wheight added as here she has just got all her walkways just lain on the deck to see if it affecks herClick image for larger version
Name:	carrier build206.jpg
            • boatman
              • Nov 2018
              • 14598
              • christopher
              • NORFOLK UK
              #261
              Now fittin in just some of her eletronicsClick image for larger version
Name:	carrier build204.jpg
              • boatman
                • Nov 2018
                • 14598
                • christopher
                • NORFOLK UK
                #262
Name:	carrier build205.jpg
                • boatman
                  • Nov 2018
                  • 14598
                  • christopher
                  • NORFOLK UK
                  #263
                  MAIN FUSE box in as she will have 5 different voltage circuts in an that's 12v '9v'6v' 3v'an 1.5 vClick image for larger version
Name:	carrier build207.jpg
                  • boatman
                    • Nov 2018
                    • 14598
                    • christopher
                    • NORFOLK UK
                    #264
                    An in the above pic can be seen just one of the 3 relays that will be in her to manage power an the black box with yellow dails is a voltage reducer
                    an here can be seen the ESC'sClick image for larger version
Name:	carrier build208.jpg
ID:	1094063 for the motors each one powers two motor's an another voltage reducer with the bow thruster in place
                    • boatman
                      • Nov 2018
                      • 14598
                      • christopher
                      • NORFOLK UK
                      #265
Name:	carrier build209.jpg
                      • boatman
                        • Nov 2018
                        • 14598
                        • christopher
                        • NORFOLK UK
                        #266
                        Here these these two unit called k7 an k8 work from the R/C all the lights on the ship there is a micro servo fitted below the unit an as its worked from R/C the cam's hit the micro knock on switches for on an off on each lights setClick image for larger version
Name:	carrier build210.jpg
                        • boatman
                          • Nov 2018
                          • 14598
                          • christopher
                          • NORFOLK UK
                          #267
                          Just some of the lights Click image for larger version
Name:	carrier build211.jpg
                          • boatman
                            • Nov 2018
                            • 14598
                            • christopher
                            • NORFOLK UK
                            #268
Name:	carrier build212.jpg
                            • boatman
                              • Nov 2018
                              • 14598
                              • christopher
                              • NORFOLK UK
                              #269
                              Red battle lightsClick image for larger version
Name:	carrier build213.jpg
                              • boatman
                                • Nov 2018
                                • 14598
                                • christopher
                                • NORFOLK UK
                                #270
                                AN NORMAL WHITEClick image for larger version
Name:	carrier build214.jpg
