BOATMAN's USS NIMITZ CVN 68 BUILD IN 1/144 SCALE
  • boatman
    • Nov 2018
    • 14498
    • christopher
    • NORFOLK UK
    #301
    NXT PIC is of the STROBE electronic unit that sent about 50 Click image for larger version
ID:	1094165white strobe lights flashin down the ruway
    • boatman
      • Nov 2018
      • 14498
      • christopher
      • NORFOLK UK
      #302
      AN more of the lights later on
      now to show the megtronics that worked the aircraft lifts elevatorsClick image for larger version
      • boatman
        • Nov 2018
        • 14498
        • christopher
        • NORFOLK UK
        #303
        AN these ones worked the hanger doors open an close as the hanger doors rode on very small rails to keep them straight to the hull
        an they were pulled open an close by very thin steel wires on pulley wheelsClick image for larger version
        • boatman
          • Nov 2018
          • 14498
          • christopher
          • NORFOLK UK
          #304
          AN FITTED IN THE SHIP there were 3 of theseClick image for larger version
          • boatman
            • Nov 2018
            • 14498
            • christopher
            • NORFOLK UK
            #305
            • boatman
              • Nov 2018
              • 14498
              • christopher
              • NORFOLK UK
              #306
              AN in the above pic if you look closely the hanger door can be seen an the wires an red an blue pulley wheels that guide the wires
              • boatman
                • Nov 2018
                • 14498
                • christopher
                • NORFOLK UK
                #307
                AnClick image for larger version
ID:	1094176 exsploded view of the above hanger door opener unit
                • boatman
                  • Nov 2018
                  • 14498
                  • christopher
                  • NORFOLK UK
                  #308
                  Now some shots of the ships defence weapons platform sponsons these are R.A.M or rollin air missles an sea sparrow missles
                  which when they are fired the missle smashes through the plastic cover an then the fins all open for flight
                  the R.A.M systemClick image for larger version
                  • boatman
                    • Nov 2018
                    • 14498
                    • christopher
                    • NORFOLK UK
                    #309
                    • boatman
                      • Nov 2018
                      • 14498
                      • christopher
                      • NORFOLK UK
                      #310
                      AN SEA SPARROW misslesClick image for larger version
                      • boatman
                        • Nov 2018
                        • 14498
                        • christopher
                        • NORFOLK UK
                        #311
                        SAME on the stern Click image for larger version
                        • boatman
                          • Nov 2018
                          • 14498
                          • christopher
                          • NORFOLK UK
                          #312
                            Apart from the build Chris those electrics look more complex than a normal house ! Have you had any problems once they are fitted, I see you do a dry run test first as with the landing light array.
                            • boatman
                              • Nov 2018
                              • 14498
                              • christopher
                              • NORFOLK UK
                              #314
                              Well John when it was all in the ship it worked ok sometimes there is a loose connection but most times I just bent the electric pin a bit an all ok that's why I did a dry test runs as you call it an if it works then in the test it normally works ok when fitted as I must admit ive been told im a bit OTT :smiling3:
                                I'd say more sensible than OTT, nothing worse in having to fault find while something is in situ.
