RPG 1/35 MK-15 MOD.31 SEARAM CIWS
  • Steve Brodie
    • Sep 2014
    • 4652
    #16
    Spent a couple of hours, doesnt time fly when your'e cutting, bending and gluing etch bits together - steps for the side vertical rotation housings;
    Cabinet finished as well;
    [ATTACH alt="20200401_152803.jpg"]378979[/ATTACH][ATTACH alt="20200401_152815.jpg"]378980[/ATTACH]
    • Steve Brodie
      • Sep 2014
      • 4652
      #17
      Dome back from a primer coat of Tamiya fine grey surface primer;
      Just to Funny - well i thought so;
        • 16310
        Hi Steve
        Looking good under primer.
        • boatman
          • Nov 2018
          • 14600
          • christopher
          • NORFOLK UK
          #19
          HI Steve this is outstanding such a model with a difference an the detail is out of this world I only wish I could have done this type of detailin on my CIWS on my Nimitz model but In 1/144 scale well it would hardly be seen keep up the good work as im enjoyin lookin at the detail on your build
          chris
          • Steve Brodie
            • Sep 2014
            • 4652
            #20
            Originally posted by Jim R
            Hi Steve
            chris
            Many thanks chaps.
            • scottie3158
              • 14638
              • Holbeach
              #21
              Steve,
              Nice result.
              • Steve Brodie
                • Sep 2014
                • 4652
                #22
                Most of the bits now primed. will need to go over the missile launch tube again to remove the black line;
                • Steve Brodie
                  • Sep 2014
                  • 4652
                  #23
                  The next step 's ( :smiling5: ) called for masks to be cut out from the instructions and attached to the uprights to allow the correct placement of steps and lifting lugs;
                  So I photocopied the page and created the masks;
ID:	1119479Click image for larger version
                  These were then blue tacked in place and a primer coat sprayed from the can over the top and when removed i had placement maps. This way i didn't risk getting plastic cement or superglue on the paper masks and not been able to remove them later;
ID:	1119481Click image for larger version
                  • Steve Brodie
                    • Sep 2014
                    • 4652
                    #24
                    Final parts added to the side rotation arms, inc 16 brass steps. All ready to be primed.
ID:	1120117Click image for larger version
ID:	1120118Click image for larger version
ID:	1120119Click image for larger version
ID:	1120120Click image for larger version
                    • scottie3158
                      • 14638
                      • Holbeach
                      #25
                      Steve,
                      Lovely work those steps must have been a patience tester.
                      • Steve Brodie
                        • Sep 2014
                        • 4652
                        #26
                        Steve,
                        Scottie, they were not that bad two ends bent ro form attachment points Step bent 90 degrees and the sides just bent round onto the foot plate.some needed a drop of glue to persuade them to stay put though.
                        • Steve Brodie
                          • Sep 2014
                          • 4652
                          #27
                          Primed the dome in tamiya white primer and the top of the missile tube. Drilled out two holes, one for a missile gone and one for a missile been launched. Brassin 1/32 sidewinders on order.Checked the shed as I was starting to sort out the mess and no XF-85 so now on order
                          • Steve Brodie
                            • Sep 2014
                            • 4652
                            #28
                            Brassin 1/32 sidewinders have arrived, and are a perfect fit for the 1/35 RIM missiles fired from the tube launchers
                            Will be held on a piece of plastic card, fins will be added and reshaped along with the seeker dome
                            • tr1ckey66
                              • Mar 2009
                              • 3592
                              #29
                              Great work Steve on an unusual kit. The photo etch makes all the difference although I suspect it will be the launching missile that will gain the immediate attention once finished.
                              Top stuff
                              Paul
                                • 16310
                                Hi Steve
                                Really neat and sorted work. The PE steps look great.
